To hard code a command into your Post Processor you should insert the code inside quotes where you want it to appear, in your example code you show it before the tool change command so that would be in Blocks 2 & 3 of the Post Processor like this :-
n,t,"M06"
"G65 P5502"
Hope that helps, save a copy of the PP to another location on your PC before you make any changes
Just open it in Notepad and simply click "save", do not use the "save as" option as it will be saved out as a .txt file that will not work in BobCAD
If you have any problems then you can Zip up a copy of the PP and upload it here and someone will make the changes for you
Regards
Rob
:rainfro: :rainfro: :rainfro:
