- Post for Fanuc
Post for Fanuc
Hi all,
Trying to modify my post for my milling, I'm with V28 and try to make it posting this command at every tool change : IF[#994EQ1] GOTO24.
It's a check to see if the commanded tool is already in the spindle, if it is, go to line 24 to continue, so no tool change.
Don't have support anymore from Bobcad, and I'm pretty new to modifying post so I thought I could ask my question here.
Thanks a lot
Re: Post for Fanuc
Thanks for your time, and glad to ear about this tool change issue, because our 3 fanuc (15t, 0i and 31i) have the same problem, we must have this line to avoid an alarm,
so do you think it would be a good idea to modify the tool change macro instead of the post ?.
- Post for Fanuc
- You may not post replies
- You may not edit your posts
Forum Rules
