Has fanuc OI-TD control 2 axis. Samsung SL30 machine for bobcad v27 lathe
The processors that I have down loaded cant get canned cycle format wright
The u and w in second line of g71 does not match what is in z allowance and x allowance
Have tried editing processor but cant get it to change
Ok, I think I know what your issue is. In V27, there was an issue with the U and W reversing the values they grab, so Z was always U and W was always X. Please attach your post processor and I will correct the output for you.
I need the post processor you are using so I can correct that issue so the correct values output. Please attach it to this ticket in zip format and I will get it updated and will attach the updated post processor for you.
What I did was remove the callout for the rough_x_allowance and rough_z_allowance variables, and substituted it for the finish x and z allowance variables, which function the same as the rough variables, but instead of getting mirrored values, it outputs the correct allowance values. Give this a try and let me know if you have any issues with it.
Hello Sean, Loaded file and this is what I got N45 G71 P50 Q65 U0.02 W0.003 F0.015. Note U is giving me double amount of what X is in cam.
Z amount is correct. U should read .0100 About a week ago I change line 249 to r and it changed U to correct amount but it changed all the X readings to. Had to change it back to d.
Hello Sean, I have another ordeal with default rapids. On Home Position X if I put in 5.00 in cam it will post 10.00 from processor.
N300 X10. in pic. It needs to match cam.
