Originally Posted by
moldmker
The different color or layer reference was just to make the selection for blanking easier (Select by Color / Select by Layer).
As you found out, it does nothing for chain-selecting overlying entities.
You need to separate the 2 chains, either by translating or blanking.
As you start using v21 and realize the processes that are required along the way, you'll pick up on ways to keep entities organized as you create them and know how they will be needed later for toolpaths.
Many times I will import a DXF and put it on it's own layer. Then just copy parts of it to a toolpath layer so I can blank the DXF layer. Then I can manipulate the toolpaths easier.
Defining layers for different tool dias. is handy as well.
v21 does work good for 2D, just need to learn the nuances. The limitations are on the 3D side and that's where v23 is stronger.
Good luck
Just reread your post: To put entities on their own layer...select them...press A to open Attribute box...under the General tab, type in or select a new layer.
