Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 04-13-2005, 05:11 PM
MIKENLN is on a distinguished road
Question having trouble getting this to cut right
i am making a part and have trouble getting it to cut the part out with bobcad 17, i created the part and when i go to create the gcode it doesn't machine it properly, i am also have a problem with island surfacing. the material is .375 plastic rod. i have it mounted on an 3c collet chuck bolted to my mill table. the endmill is .119 flat endmill. maybe someone could try it out, i am machining it on my homier mini mill and using maxnc software. thanks mike
:BANNANA:
Old 04-15-2005, 11:07 PM
carbidecraters's Avatar
carbidecraters is on a distinguished road
Are you trying to make this as a boss? Could you program the square part after you mill the top? Looks over complicated and has too many entities for what it is
Old 04-19-2005, 02:24 AM
the square part is the top and it needs to be in the middle of the 3/8 rod for proper fit. yes i guess you could say its a boss. mikenln
:BANNANA:
Kcam Cut depth 47MLB Kellyware CAM 6 01-18-2012 01:04 PM
Having trouble cutting aluminum sheet fastturbovet General Metalwork Discussion 40 06-14-2005 10:33 PM
rotary 4 ax depth of cut q. nervis1 Mastercam 4 03-24-2005 04:34 PM
cut single, cut auto and cut all??? fastolds BobCad-Cam 3 10-06-2004 08:15 AM
PICS - BOAT HULL CUT WITH CNC ninewgt DIY-CNC Router Table Machines 16 08-02-2004 06:21 PM
