| BobCad-Cam Discuss all BobCad software here. |
I bought the upgrade to V20 and they also sold me on the Bob-Art. I don't know how often I will actually use the Bob-Art, but it will be nice to have it if I do decide to do some of that kind of work. The importing of files is dead right, I imported a couple of different files that I couldn't import into V17 and they were awesome, not a line or arc or even point out of place. One concern I have is the documentation, how detailed is the manual? The manuals I got with V17 were ok, but left me with a lot of questions that I had to answer on my own thru trial and error. I downloaded the demo, and from what I can figure out it will be a vast improvement over trying to do 3d work in V17. Seems that creating surfaces is now an easy thing to do. I haven't gotten too deep into toolpaths, but from skimming thru it, it reminded me a lot of Mastercam, with all the tool details, roughing and finishing passes and such. How much modification can be done to the post processor? Can it be completely modified for anything you need or is it limited to only certain variables? (I need to change the Peck Drill, Peck designator, from a Q to an E, can that be done in the post?) I'll try and let you guys know how it works out for me. BTW, I am mainly going to be using it for Moldmaking, 3D milling mostly. Jim
__________________ www.maverickmoldandtool.com |
| One thing I realized about Bobcad years ago when I bought V17, there is always a lower price. I knew that whenever I bought V20 it wouldn't be long until I saw it advertised for less than I paid, that's just how it works. It kind-of bothers me that there is no set price for this software, but hey what can you do? The guys got to make a living, and if they have to dicker on price to keep their families fed then I ok with that. One thing I was not aware of is that there is a software registration process you have to go through before you can unlock the software to the full version. I was in a pinch to get this software up and running so I installed it on my shop pc. I am now wondering if I should have waited until I got a new pc but I can't do anything about that now either. I am currently working on getting my setup right for my machine, the old setup I used for V17 worked ok for sending and receiving and even the program start and stop and configuration of coordinates and decimals and such, but I can't figure out where my drilling cycles are. I haven't had time to really work with it though I've been busy with other work. I was really impressed with the manual, a far cry from the three booklets and the hand-out I got with V17. There is extensive instructions about how the mouse works and how to pick entities and such, which is one part of V17 that still gives me fits sometimes. There is a section in there about scripts and how to modify them, so I think I will be able to modify the G83 cycle to work for me, but first I got to read the book. I'll keep you guys updated. BTW, Chamm128, I won't say how much I paid, because as soon as I do someone will post that they got the upgrade cheaper, and I am in no hurry to hear that although I know I will. Jim
| Well I have learned a bit more about V20 and I have to say I like what I see. It has some quirks, things I don't understand exactly and things that should probably be different. But for the most part it is leaps and bounds better than v17. One thing that gave me fits is that when you create a small surface and then zoom out to look at the overall part, the 3d surface is not in the position that it should be. I think it is this way so that you can see the different geometry, but it messes with your mind when you are looking at it, makes you think it moved for some reason. Another quirk I have found and I can't explain, is that when I generate a toolpath using a surface, there is a difference between what you put in the dialog boxes and what you get in the program. I programmed a tapered surface with the top of the work being at 0.0000 and the depth of the cut to be -0.3510. the resulting program had a maximum cutting depth of -0.3265. I don't understand what happened, I used the program and the X-Y coordinates where exactly right, I just had to adjust the Z to make the cut to proper depth. My computer died on me today too, so I am going to be buying a new computer, and I have e-mailed Tech Support to find out what I need to do to get it onto the new pc. Maybe a better PC will solve this problem. Jim Estes
| Jim 20 has some nice features. I think 17's interface was alot better as it followed the early mastercam programs. We bought 19 and one month later they has 20 for sale...they didnt mention 20 was even in the works when we bought it. Also these programs have a feel like they were rushed out the door....service and satisfaction on bobcad programs ....I give it a 3 out of 10. I liked 17...19 and 20 can kiss my arse |
| So when you register Bobcad, It's "locked" onto the pc you install it on??
It really is very easy to use, and will do a better job of some stuff then adobe streamline. It will not smooth the paths like adobe but it will do a better job of bringing in marginal type files. It is easier to see your changes in your bit map then adobe. You have to convert it first in abobe, where bobcad you can slide a control and see the changes real time. |
#10
| Mr. Knife, I'm not sure how they do it, but I had to fax them a sheet with two codes that came up whenever I installed the software. They then faxed me back another code that I input into the software and that unlocked the software from the demo mode. My old shop pc took a dump and now I can't get it working again. So now I have to find out what I need to do to get it onto a new pc, I'm hoping I don't have to pay more money but I am sure it won't be as easy as asking for them to let me install it on another pc. I haven't heard back from them yet so I guess I'll be giving them a call tomorrow. Jim
#11
| Well I'm back up and running with version 20 and it's a good thing too because I have a ton or work to do. The new computer makes 3d work a lot faster. It is a bummer though that the new pc doesn't come with a floppy drive, but oh well I can get a thumb drive and do a lot more with it.
#12
| Jim, If you really need a floppy, look for one of those multi-purpose card reader things, with floppy drive included. It plugs into USB. Its nice, I have one for my newest computer. But, if you can use the flash drive instead, that is great.
| SCM Router controller upgrade help | flinty | General CNC (Mill and Lathe) Control Software (NC) | 0 | 04-26-2005 03:20 AM |
| BobCAD-CAM V20 vs. Rhino3D + RhinoCAM | haysys | General CAM Discussion | 13 | 04-21-2005 09:33 PM |
| V20 post processors | doug6949 | BobCad-Cam | 5 | 02-22-2005 07:49 AM |
| Ballscrew upgrade for Taig Mill????? | Philip | Taig Mills & Lathes | 1 | 12-01-2004 10:08 AM |
| What kind of motors have i just bought? | jsatter | DIY-CNC Router Table Machines | 8 | 02-07-2004 04:14 PM |
