Results 1 to 2 of 2
Thread: V23 crashing when saving file as DXF or DWG
    Registered Chipload's Avatar
    Apr 2007
    So I was saving a file with V23 as a DXF to use the print on a different software. Unknowingly, I had some geometry blanked out. When I saved this file as a DXF with having some geometry blanked out, bobcad V23 crashed on me (shutdown). Ever since then, whenever I save a file with V23 as a DXF or DWG bobcad continues to crash regardless if geometry is or is not blanked out. Running Windows Vista, Bobcad V23 build 1493 I believe. Anyone else have this problem?
    Nov 2009
    UK
    you lucky b......
    I have a problem also with BobCad and Vista.
    Mine just doesn't work at all anymore.
    I've even tried repair.
    And uninstall and reinstall.
    And messing with the registry.
    So count yourself lucky.
  1. Newbie- Saving a file
    By bjm323 in forum Mastercam
    Last Post: 11-23-2008, 12:22 PM
  2. Newbie- Saving file
    Last Post: 10-15-2008, 07:05 PM
  3. V22 - Crashing upon file/open
    By tikka308 in forum BobCad-Cam
    Last Post: 12-15-2007, 08:44 AM
  4. Saving a File
    By utahnorton in forum AjaxCNC Control Products
    Last Post: 12-28-2006, 10:10 PM
  5. Saving a Text file?
    By Scott V in forum BobCad-Cam
    Last Post: 11-23-2004, 09:27 PM
