Results 1 to 2 of 2
Thread: V23 grooving without roughing, want to just finish groove
    Jan 2006
    united states
    Hi all,
    I am new with using Bobcad and have a machining situation on a lathe where I would like to skip the roughing pecks that a grooving cycle does on a diameter. I would rather it do just the finish passes as the material is just alum. Is there a way to get the finish cycle without using the roughing cycle first?
    Thanks,
    Chad
    Registered BurrMan's Avatar
    Dec 2008
    Hi Chad,
    I think the cycle type in the feature edit. Just choose one of the single op types. Put 0 for your peck values. I'm not much of a lathe guy so I could be wrong. If this doesnt do it, can you be more specific? Even post a file is better.
  1. Need Help!- Grooving HELP!
    By modeltruckshop@ in forum General Metal Working Machines
    Last Post: 04-22-2009, 09:49 PM
  2. Zinc-Plated Finish vs plain finish for threaded rod?
    By Almaz in forum DIY CNC Router Table Machines
    Last Post: 10-21-2008, 03:39 PM
  3. face grooving 304L for 32 finish
    By mlanders in forum General Metalwork Discussion
    Last Post: 09-03-2008, 01:54 PM
  4. deep grooving
    By eject_21 in forum G-Code Programing
    Last Post: 06-15-2007, 01:59 AM
  5. What is the G code for Grooving? Not G75?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 04-22-2007, 06:07 PM
