You really don't need a model for pocketting.
Just draw the profile of your pocket.
Chain select it.
Select Other>Pocket...>Spiral (the Pocket selection is greyed out until you have a pocket profile preselected)
If your CAM window is open, you can go right into generating code by setting your roughing/depth parameters then selecting Cut Auto.
Good luck,
moldmker
LinkBack URL
About LinkBacks
