Results 1 to 5 of 5
Thread: Helical Ramp Toolpath
    Oct 2008
    UK
    Hello
    I am wanting to machine the outside of the profile in the attached file using a helical ramp toolpath if possible. Does anyone know if ths can be done in Bobcad?
    The stock is 3 3/4" stainless 316L. I am currently machining in 1mm deep steps, to a depth of 65mm, at 2000 rpm and 3000mm/min feed with a 5 tip, 32mm dia tool, but each feed in gives me a "hard" entry, & shortens the life of the tips.
    Thanks in advance
    Attached Files Attached Files
    Registered BurrMan's Avatar
    Dec 2008
    Here is a link with a file in it where John created a path like this:
    http://www.bobcadsupport.com/forum/s...89&postcount=6
    There can be some other methods like using the HSP and creating a pocket that will provide the ramped toolpath in a single stroke.
    Oct 2008
    UK
    Thanks BurrMan,
    Managed to get the tool ramping down almost as I want, It travels 360 deg anti-clockwise, then 360 deg clockwise, until it reaches the bottom of the part, and I am saving about 1min. per run.
    I asked Bobcad about HSP, but thes suggested it wasn't suitable for the part.
    Dec 2008
    Yeah the profile feature doesnt do ramping so all the suggestions will be "ways to make it work" kind of things. I dont have any good suggestions but I have seen others do this with different methods.
    Oct 2008
    UK
    Read the posts the link you provided & produced a z-level finish toolpath, worked perfectly using ramp entry and s-links, lost a further minute
    1. Newbie- Can BobCad do this? (fly, boring, ramp)
      By Ed from NY in forum BobCad-Cam
      Last Post: 07-22-2009, 03:43 PM
    2. RAMP out on a Pocket
      By Allen123 in forum General Metalwork Discussion
      Last Post: 06-12-2009, 01:41 PM
    3. To Ramp or to Plunge?
      By bborb in forum General Metalwork Discussion
      Last Post: 01-22-2009, 09:50 AM
    4. Problem- ramp milling
      By almachinist in forum Fanuc
      Last Post: 01-20-2009, 10:36 AM
    5. Ramp in Z Toolpath
      By solgood in forum BobCad-Cam
      Last Post: 08-14-2006, 11:35 PM
