Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 03-16-2005, 12:44 AM
Klox's Avatar
Gold Member
Klox is on a distinguished road
Talking Need simple milling & turning sample
Can anyone help me with a simple milling sample program i can use to help me on learning BobCad 18.
A lathe sample would be also appreciated.
Upload the sample for others so that all can benefit.
Klox,
the edm idiot
*** KloX ***
I'm lazy, I'm only "sparking" when the EDM is running....
Old 04-13-2005, 05:26 PM
MIKENLN is on a distinguished road
here is a part that i was trying to make. having trouble getting it to cut right. mike
:BANNANA:
Old 04-13-2005, 08:22 PM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
here's a simple pocket..it's just the tool paths with no offsets. I generate a G-code and use mach3 to set the depth in multipass. Was intended for a !/8" bit.
I think I do it a hard way though....just tweak the G-code to advance cutter from one path to the next...
The second txt file G-code is cleaned up a little....still errors but I was in a hurry to get the motor mounted.
Old 04-13-2005, 08:46 PM
Bloy2004's Avatar
Fumbling Machinist
Also, here's a motor mount again for 1/8" bit but with offsets in drawing. Mach3 is used again for multipass to cut through a 5/16" aluminum plate. There are two G-codes in the text file....the first is after tweaking and adding ramps...The second is the original from BobCad.......and I still don't know what I'm doing to make it easier.
Old 04-14-2005, 01:25 AM
Klox's Avatar
Gold Member
Thanx gentleman! I'll take a look....
*** KloX ***
Old 04-11-2010, 07:31 AM
melon_khan is on a distinguished road
Hi , Can i get simple milling operation program ? This is very important to my. I am waiting your reply with a program.
Old 04-11-2010, 07:36 AM
sir, I need simple milling operation CNC program. How can I get this ? I think this will supply me from you. So I am waiting your reply with this program as soon as possible. Bye
Thread milling, can anyone help jtrav General CAM Discussion 16 03-06-2006 02:25 PM
Why would this machine be bad for milling? jevs Knee Vertical Mills 5 06-16-2005 10:49 PM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 02:43 PM
A System For Milling And Turning kathepati FeatureCAM CAD/CAM 2 03-20-2005 09:46 PM
Recommendations for a practical and complete S/W combination for simple 2d Milling ngr1 General CAM Discussion 6 01-10-2004 06:36 PM
