Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 10-08-2009, 10:36 AM
renman is on a distinguished road
v19 with 4axis hotwire
I have v19 that came with our 4axis foam hot wire machine.
I am trying to make a tapered shape with two similar profiles on each end. After importing a dxf with the two profiles and their restriction lines between them, the shapes are not closed which doesn’t allow the two chains to be selected during toolpathing.
I know this can be done because a previous employee made a tapered cylinder half.
Anyone know what I could be doing incorrectly.
Thanks in advance.
hotwire controller diy eloid CNC Wire Foam Cutter Machines 6 07-28-2009 08:16 PM
hotwire an AC servo Karl_T Servo Motors and Drives 5 05-03-2009 12:14 PM
Which hotwire machine to buy dizzywizzy Want To Buy...Need help! 2 04-21-2008 03:05 PM
I'm looking to job hotwire work out decor designer CNC Wire Foam Cutter Machines 1 07-29-2007 08:03 PM
I'm looking to job hotwire work out decor designer Employment Opportunity 0 08-21-2006 08:05 PM
