If you put .010 in side allowance on the parameters page in the edit section, then on the tools put a roughing and finishing tool number, it will do what your wanting to do.
The roughing tool and finish tool can be the same number.
Tommy
So here's my question. When you set up a profile tool path it asks if you want one cut, or mutiple cuts. then it also asks for a finish pass. well here's my problem. i want to cut a 1/4" piece of material with an 1/8" end mill. i want to leave .010" of finish material on the side. so i do a multiple cuts pass with it cutting .062/cut deep, total of 4 roughing cuts. well what i want is for the finish cut of .010 to be cut at full .25" depth. is there a way to do this without creating two seperate profiles. see if i do the multiple cuts for my rough then it wants to take 4 finish passes at .062 depth per cut. well that's not at all necessary for my finish, i just want 1 full depth finish pass. anyone had this problem or know a way around it? Thanks!
-Nate
Tommy
right, i know what you're saying with creating the finish cut. the problem i have is when doing it that way, instead of taking one finish pass at full depth it will take 4 finish passes at .062 depth, like the parameters show. well having 4 finish passes at .062 depth is crazy, i just want one finish pass at full depth. I understand what you're saying and yeah that's how you do it but like i said, when doing it like that it wants to take 4 finish passes instead of one.
Can you post a picture of your settings like I did, and then a picture of the tool paths after you compute tool path?
Maybe you are trying to do it with 2 different operations and you are putting a roughing tool in both. You can do it this way too. Just put 0 for the tool size in the roughing tool.
I think I can help you more if you can post a few screen shots.
Tommy
I opened your part and it looks like you are getting one cut for the Finish pass. The colors are the same as the Roughing cut, so it may be a bit confusing.
Do this:
Click the plus sign next to the Profile Feature.
Then click the plus sign next to Profile, you should see Rough and Finish below it.
Right click on the Finish item and choose color.
Select something other than green and click OK. You should see that there is one pass generated for the Finish Tool. If not, post the code and we can see what is happening.
Regards
They must be out of Hawaiian coffee. I'll have to send some off!![]()
The "Hippie" Emoticon is a nice touch Rob!![]()
Yep, a muticoloured Afro, appealed to me as a sort of combination of the Sixties and Seventies!
A mix of Psychedelia and Shaft!!
Kind of captures the spirit of the era I thought!!!
Ultra Coooooooooooooll
Regards
Rob
Rob,
You're a Bad Mutha FJohn Shaft!
