Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 09-10-2009, 04:58 PM
southernexplore is on a distinguished road
Unexpected file format
What is "unexpected file format"?
I have seen this before and I thought I saved a drawing without the dongle,
but I know it was in when I saved it.
How do I get it back?
Tommt
Old 09-10-2009, 06:19 PM
SBC Cycle is on a distinguished road
See my reply in your other thread. This happens when one of two (maybe more) things happen.
1: A CAM feature gets corrupted that is stored with the drawing. This happened in Build 1465 when manual tools were used. The system would store the manual tool length as -0 which sucked.
2: This also happens if you try to open a file saved in - say Build 1478 - and attempt to open in an older build - say 1326. The older build won't recognize the new features added to the system.
Old 09-10-2009, 06:31 PM
That sucks!!
I remembered I did a backup a while back and it had the drawing on it but i moved a few things around before I cammed it.
Tommy
Old 09-10-2009, 10:10 PM
Ed from NY is on a distinguished road
I save my work every 15 minutes or so with a different name. It works well as well when I change my mind and decide to go back to a previous version to redo something.
Old 09-10-2009, 10:21 PM
I am glad I did the backup. Never the less I will start doing a backup more often.
I sure hope Bobcad fixes this one. I am starting to use it more and more since V23 came out.
Thanks for the help,
Tommy
Old 09-11-2009, 01:35 AM
BurrMan is on a distinguished road
This has been fixed in a test build they put up for users to try. The release should be up soon I hear. Hang in there.
Old 09-26-2009, 07:06 AM
Chipload's Avatar
Chipload is on a distinguished road
I have been able to merge the corrupted file into a new drawing. The CAD information will transfer but the CAM information is not there however
Old 09-26-2009, 08:41 AM
dcskid is on a distinguished road
The CAM doesn't come in. I believe the problem was manual tools being used.
Old 09-26-2009, 01:52 PM
The updated Version usually opens the old file with the Cam info too. I'm using 1493.
anyone have the DSTV file format? ABC123 General CAM Discussion 21 07-28-2009 11:38 AM
DSTV file format? ABC123 General CAM Discussion 7 01-16-2009 05:37 AM
Problem- V22 Unexpected File Format? argo cnc BobCad-Cam 2 08-28-2008 11:32 AM
Understanding file format osaris Mazak, Mitsubishi, Mazatrol 3 04-01-2007 07:38 PM
?Best? transportable CAD file format? vladdy General CAM Discussion 4 11-08-2005 08:40 AM
