Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 08-22-2009, 03:34 PM
alex 850 is on a distinguished road
bobcad mach3 question
i have been useing mach 3 for a couple of years now with my autcad drawings. when i import autocad dxf files into lazycam it always puts my tool starting at the bottom left of my drawing so i know where to make my fixture set up . when. i load a gcode file from bobcad version 23 the tool always ends up in a different starting place .how do i fix this ?
thanks alex
Old 08-25-2009, 06:34 AM
mcphill is on a distinguished road
Alex, not sure I follow your question, but try this. Make sure you position your drawing over X0 Y0 in BobCAD. The CAM side will key off of the axes for position, so if you draw them "way out in space", you better have a big table to take that in to account!
For the Z axis, you define the heights in the CAM tool you right. Inside the tool (pocket, Z level, whatever 2 or 3D tool you select), you choose the Material Height in the first setting. You don't have to follow the model on this one. If you want to set the top of your part at 0, select 0 here. If you want it to be at 1" on the mill, put in 1. Also select the clearance from that height for your rapids - this could be important if you are using clamps, but usually I just use .1" to clear the part.
Finally, when on your mill, you need to set the tool at 0,0,0 on the part (with respect to what you entered in BobCAD), and rezero all axes. Then you should ALSO (in my experience) select "Ref All Home", and rezero them again. If you don't do that, you might find the tool diving in to the material! (don't ask how I know).
Hope that is enough to get you moving along, post up further questions if needed.
Old 08-25-2009, 08:24 AM
thanks for the reply! i will give it a go tonight an post you back on my progress.
thanks alex
Need Help!- BOBCAD V23 Code for Mach3 adel_acameron Mach Mill 3 03-22-2009 03:25 PM
Need Help!- BobCad v22 cutterpaths that MACH3 doesn't like??! hodge98ws6 BobCad-Cam 5 07-04-2008 10:02 PM
Bobcad for Mach3 post processors duraflap BobCad-Cam 2 10-28-2007 09:16 AM
Mach3 / Bobcad V21 file help Dfennell Mach Mill 11 03-25-2007 12:48 PM
BobCAD/CAM V21 and Mach3 Postprocessor southernexplore BobCad-Cam 33 07-25-2006 12:28 AM
