I don't have HSP but I think it is quite normal to have much more code than simple pocketing. There is a lot of info on this at the BCC support site.
Can anybody show me how to setup high speed pocketing when we make code with it it is twice as long as a regular pocket? It is like every thing else you get from bobcad you bye you figure it out on your own!
The actual cut will be much faster![]()
I upgraded to HSP -- does it ever end?
I'm itching to try it. I have a project where I'll need to mill about 77 cubic inches of steel... will also need to figure out how to re-position it... probably 2-3 times to cover the entire surface as the stock is 12x8x1 and I have a puny SX3 with an effective work envelope of 5x12 :lol:
Holy huge material, Batman!
