Results 1 to 5 of 5
Thread: How to get darker print of drawing V23
    Registered SteveS's Avatar
    Oct 2004
    CORRECTION - This is with V21
    I have had this problem for some time, but it is now getting really annoying.
    I have the line color as black, but printing comes out very light almost light grey. Even when printing to a pdf it is light.
    My work around is to save as dxf, read in corel and output to pdf. Not the most efficient.
    Searched back 20 pages in these threads and didn't find anyone else complaining, so it must be me.
    Steve.
    Registered Swag's Avatar
    Jul 2006
    USSA
    Printing in V21
    Steve
    Try on the attributes to change the line width to .010" or .020"
    That should print better than a line width of 0.000 It is most likely your
    problem.
    Mark
    "I'll keep my gun, my ammo, my money, my freedom and you can keep the [COLOR="Red"]"CHANGE"[/COLOR] !
    Oct 2004
    Mark,
    That solved it. Knew it had to be an oversight on my part.
    Thanks for the quick response.
    Steve.
    Moderator HuFlungDung's Avatar
    Mar 2003
    It may also work to change your printer setting from 600 dpi to 300 dpi. I found in my own cadcam software, that this was a quick way to get the dimensions and dimension text to print out with better visibility, since some of these things have virtually zero thickness, or so it would seem.
    Jul 2006
    USSA
    V21 Printing
    Actually, I just tried both the 300 dpi didn't work good here,
    but even making the line atributes to .005" came out fine !
    Steve,
    Glad I could help, simple enough.
    Mark
    1. cant print?
      By erase42 in forum BobCad-Cam
      Last Post: 11-30-2009, 09:05 AM
    2. Need Help!- Is there a way to have BC print out a Blue Print of a drawling?
      By Stampede in forum BobCad-Cam
      Last Post: 01-05-2009, 08:36 AM
    3. Need Help!- No Print or Drawing
      By operations1 in forum DynaTorch
      Last Post: 10-01-2008, 07:57 PM
    4. Need Help!- converting imported part drawing to mold drawing
      By msomerville in forum BobCad-Cam
      Last Post: 08-29-2008, 07:56 AM
    5. 2d print from solidworks
      By Kool Parts in forum Solidworks
      Last Post: 02-03-2005, 10:12 AM
