Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 07-19-2009, 07:05 PM
Ed from NY is on a distinguished road
Center Drill Depth
I looked and searched and the only way I found to change the depth of the center drill step in the drill pattern is to lie about the angle of the tool.
An angle of 150 degrees gave me 0.0214" which is about what I was looking for... weird.
As an aside, I suppose there is a way to create a new tool pattern of a drill without the center drill step -- while keeping the existing drill pattern for when you want the center drill. Did not get to look into that yet.
Old 07-19-2009, 09:04 PM
BurrMan is on a distinguished road
Ed,
On the Parameters page of the Center Drill feature there is a Manual Overide button for the depth. Does this not do what you are asking?
Old 07-20-2009, 06:56 AM
Originally Posted by BurrMan View Post
Ed,
This is in the "Drill" Feature which has 2 steps/tools: center-drill and drill. I do not think that in this feature it allows you to specify the depth.
Old 07-20-2009, 04:51 PM
Under the "Hole" feature edit, on the parameters page, if you select "Peck" a field for first and second peck appear. I wonder if the first peck is the center drill?
Old 07-20-2009, 06:22 PM
Peck drilling drills a bit, pulls out, drill a bit more, pulls out, etc.
It lets chips out, breaks barbs and gets coolant in... me thinks. I have used on air.
Trying to solve another problem on how much HP we really have on my mill now. Once we pass that part I'll probably get to video the pecking
Old 07-20-2009, 06:23 PM
Answered my own question.
No!
Old 07-20-2009, 06:25 PM
I suppose at this point you will just have to make 2 features. One for center drill with depth you want and then the hole with the centerdrill removed.
Old 07-20-2009, 08:39 PM
Can you do your own features???
Is there a tutorial?
Old 07-21-2009, 12:41 AM
Ed,
What I meant was to just create a Center drill feature that has the depth override function, then create a hole feature to do the drilling. From the tool Pattern menu you can delete the center drill tool from the second feature. You can use the "part" settings to do it only for this operation so you can leave the hole function alone for other operations.
Old 07-21-2009, 03:19 PM
Ed,
Ah!
Smart.
Here is the test video I mentioned... In the 2nd try, the one that works, you can see the peck working at 0.125"
  #11   Ban this user!
Old 07-22-2009, 11:16 AM
dcskid is on a distinguished road
Stringy chips
I was taught to slow down rpm's or increase feed rate to get the chips to stop tangling up. See if it works for you.
David
  #12   Ban this user!
Old 07-22-2009, 02:21 PM
Isnt there some kind of tool that attaches to the spindle that breaks that stuff off. A 3 footer could reach out and grab you and take a piece back with it!
Removal of the drill press depth stop threaded rod devinchi Shopmaster/Shoptask 4 03-14-2010 09:10 AM
How to Add Digital Depth Guage To Drill Press cbrussell General Metal Working Machines 1 01-31-2009 02:01 PM
Center Drill Drill Depth bowersjack General Metalwork Discussion 4 01-28-2008 08:53 PM
Problem with drill depth Alan S Post Processors for MC 2 11-03-2005 02:23 AM
Do I need to center drill? jderou General Metalwork Discussion 9 06-15-2005 09:33 AM
