Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 07-13-2009, 02:57 PM
nfrees114 is on a distinguished road
My G Code Posting isn't in order
So I have tool pathed my whole part and computed everything. then realized i wanted a finish pass on an o-ring groove that i programmed earlier. well i went in and put in a finish pass. i clicked on the tool path according to the tool used so that it would do the finish pass while it had that tool doing other work. well for some reason it put the finish pass of this o-ring groove at the end of the program. now it does the 1/8" end mill work then does a Drill, tap and then pulls the 1/8" tool again to do the finish pass. what i was wondering is there any way to re-arrange the order of the program and then re-post it, other than clicking on the "arrange by tool" and "arrange by feature" buttons?
Thanks!
-Nate
Old 07-13-2009, 03:09 PM
BurrMan is on a distinguished road
You can drag them in order in the cam tree. Drag top down if the top one doesnt shift if you drag bottom up. Also, when you create the feature, create it from the previous feature and not the Milling Stock pick.
Old 07-13-2009, 03:17 PM
Ok I understand what you're saying. the problem i have is, isn't the finish pass inside the feature? I have the O Ring Groove feature above the tap drill and such. and it does the o ring groove before the tap drill but it does the finish pass afterwords. It's kinda odd if you ask me. I'll play around with it though and see what i can figure out.
Old 07-13-2009, 04:08 PM
Sounds like its doing all the roughing tools then the finish tools. Make a change in your machine order under CAM Part-Milling Tools-Part and see how it posts.
?? about posting code in v22 JDsto BobCad-Cam 5 01-13-2008 11:34 AM
Lcam G-code posting problems Holescreek Mach Wizards, Macros, & Addons 2 01-06-2008 01:31 PM
Having problems posting code. Stampede BobCad-Cam 3 10-27-2007 11:18 AM
Problem posting G-code. josh_75964 LazyCam 2 09-12-2007 02:14 PM
G-code optimization and Cuttin order NeoMiller General CAM Discussion 3 12-10-2003 06:23 PM
