Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 07-08-2009, 12:17 PM
cncamo is on a distinguished road
Angry BobCad V22-snap points
I am a new user of BobCad and I need help with using the snap points. In Mastercam when I use the create line function, I can pick my start and end points by snaping to the midpoint or endpoint of a line or by snaping to the quadrant of arcs. How is this done in Version 22 of BobCad? I have tried to set the snap points, but it never works. Is it so simple I'm over looking it, or is it just not possible?
Old 07-08-2009, 02:31 PM
mcphill is on a distinguished road
Try holding shift, alt, or ctrl when you pick it. Can't recall which one it is.
Old 07-08-2009, 04:32 PM
Unhappy No luck yet.
Just tried all three and still nothing.... I am using the line sketch function, is that the correct function?
Old 07-08-2009, 06:02 PM
BurrMan is on a distinguished road
use the line continuous function. and shift click. You Can then use the break or divide function to get more points if you need them.
Old 07-09-2009, 05:15 PM
Talking Got it.
That seems to work. Thanks alot!!!
Old 07-09-2009, 05:29 PM
You will also notice that it will automatically use these snaps once the command has started. Doing the shift click is for the first selection, then if you just need to see whats available for the next snap.
Machining snap ring groove Cairns General Metalwork Discussion 5 07-04-2008 02:34 PM
How to turn on @#$%@#$% snap to grid? InspirationTool TurboCAD/CAM 5 12-10-2007 05:57 PM
Snap-On consumables Captain Midnigh CNC Plasma and Waterjet Machines 2 01-06-2007 01:22 AM
ok silly question. Snap in capacitors tekno General Electronics Discussion 5 04-13-2006 08:48 PM
