| BobCad-Cam Discuss all BobCad software here. |
Hi ![]() I'm doing my first piece in BobCad v21.5.3 and I'm not sure if there are better ways to do it. The first picture is a rendering of the piece, actually doing 2 work pieces from one piece of stock. They are 5x3.5x1 on Nylon 6. The second picture has all the auxiliary lines I need still done in Autocad (easier to do them there because of osnap, etc.). The 3rd picture is the import on BobCad after I added the points to use for drilling (done using Point/Intersect on the imported construction lines). So far I generated the G-code to drill the holes and now I'm working on the pockets. BTW the through holes are peck holes, just to give it a try and see if my mill does them. Code: // small thru holes M5 M9 G0 G28 G91 Z0. T1 M6 S0 M3 G90 G54 X0. Y0. G43 H1 D1 Z3. M8 G73X-0.875Y3.75Z1.2R-.1Q.4F25 X-2.5Y3.825 X-4.125Y3.9 Y1.1 X-2.5Y1.175 X-0.875Y1.25 X1.625Y1.1 X3.25Y1.175 X4.875Y1.25 Y3.75 X3.25Y3.825 X1.625Y3.9 G80 // countersunk holes M5 M9 G0 G28 G91 Z0. T2 M6 S0 M3 G90 G54 X0. Y0. G43 H2 D2 Z3. M8 G81X-0.875Y3.75Z.25R-.1F25 X-2.5Y3.825 X-4.125Y3.9 Y1.1 X-2.5Y1.175 X-0.875Y1.25 X1.625Y1.1 X3.25Y1.175 X4.875Y1.25 Y3.75 X3.25Y3.825 X1.625Y3.9 G80 In order to make a pocket it seems I have to do 3 operations being careful not to mess up. 1) Rough in the pocket lying about the tool diameter (say it is 0.51 instead of 0.50) and select an artificial Z (-0.745 instead of the pocket bottom at -0.75) so that the rough box is within the finishing box by 50 mils (or less if you want). Since my pocket bleeds into the piece perimeter the wire frame boundary is slightly larger than the pocket itself in the side it bleeds over. That is the light blue line in the attached. 2) Then you do the contour telling BobCad the real diameter of the tool (0.50) and the real depth (-0.75). The contour uses the same light blue line as the boundary in the previous step. However, since we lied about the tool diameter then we get to finish it now. 3) Lastly you finish the pocket bottom at the real depth (-0.75), but with a fake tool diameter (0.51 instead of 0.50) so we do not touch the finished walls. Am I going in the right direction? Comments, suggestions? Thanks! |
| I did the 1st step, that is the roughing, but there is an awful lot of plunging. See the picture and commented g-code attached. Code: // roughing Y1.505 G01Z-0.2483F25 // real plunge to begin 1st pass X0.3698 X1.9343Y1.735 X0.33 Y1.965 X2.5601 X2.5939Y1.9782 Z0. // going up to top of material X3.1488Y2.195 // - traversal scratching top of material X3.1356 // - traversal scratching top of material Z-0.2483 // plunging back X0.33 Y2.425 X3.897 X3.8975Z0. // going up to top of material while traversing 5 mills in X X3.909 // - traversal scratching top of material X3.9064Y2.4269 // - traversal scratching top of material Z-0.2483 // plunging back X3.5919Y2.6513 Z0. // going up to top of material X3.5866Y2.655 // - traversal scratching top of material X3.5794 // - traversal scratching top of material Z-0.2483 // plunging back X0.33 Y2.885 X2.93 Z0. // going up to top of material X2.9194Y2.8893 // - traversal scratching top of material Z-0.2483 // plunging back X2.3536Y3.115 X0.33 Y3.345 X1.6164 X0.3698Y3.495 X0.33 G00Z0.1 // going up to rapid plane Y1.505 G01Z-0.4967 // real plunge to begin 2nd pass X0.3698 X1.9343Y1.735 X0.33 Y1.965 X2.5601 X2.5939Y1.9782 Z0. // going up to top of material X3.1488Y2.195 // - traversal scratching top of material X3.1356 // - traversal scratching top of material Z-0.4967 // plunging back X0.33 Y2.425 X3.897 X3.8975Z0. // going up to top of material while traversing 5 mills in X X3.909 // - traversal scratching top of material X3.9064Y2.4269 // - traversal scratching top of material Z-0.4967 // plunging back X3.5919Y2.6513 Z0. // going up to top of material X3.5866Y2.655 // - traversal scratching top of material X3.5794 // - traversal scratching top of material Z-0.4967 // plunging back X0.33 Y2.885 X2.93 Z0. // going up to top of material X2.9194Y2.8893 // - traversal scratching top of material Z-0.4967 // plunging back X2.3536Y3.115 X0.33 Y3.345 X1.6164 X0.3698Y3.495 X0.33 G00Z0.1 // going up to rapid plane Y1.505 G01Z-0.745 // real plunge to begin 3rd pass X0.3698 X1.9343Y1.735 X0.33 Y1.965 X2.5601 X2.5939Y1.9782 Z0. // going up to top of material X3.1488Y2.195 // - traversal scratching top of material X3.1356 // - traversal scratching top of material Z-0.745 // plunging back X0.33 Y2.425 X3.897 X3.8975Z0. // going up to top of material while traversing 5 mills in X X3.909 // - traversal scratching top of material X3.9064Y2.4269 // - traversal scratching top of material Z-0.745 // plunging back X3.5919Y2.6513 Z0. // going up to top of material X3.5866Y2.655 // - traversal scratching top of material X3.5794 // - traversal scratching top of material Z-0.745 // plunging back X0.33 Y2.885 X2.93 Z0. // going up to top of material X2.9194Y2.8893 // - traversal scratching top of material Z-0.745 // plunging back X2.3536Y3.115 X0.33 Y3.345 X1.6164 X0.3698Y3.495 X0.33 G00Z0.1 // going up to rapid plane and... DONE! |
| Okay, I think I figured out what is happening. The curve is convex in certain areas (see attached) and the path is not smart enough to (a) use an arc, or (b) offer an option to stop short or (c) really clear the material before traversing. Bummer, I'll try the spiral. |
| Hmmm... spiral kinds of follow the outside contour, but it is worse since you have a lot more ups and downs and the generated code is much larger. Code: Z0.505 X-4.7295Y2.2456 G01Z0.005F25 X-4.4633Y2.2842 X-4.0209Y2.395 X-3.7272Y2.5 X-4.0209Y2.605 X-4.4633Y2.7158 X-4.7295Y2.7544 Y2.2457 X-4.6964Y2.018 X-4.4187Y2.0583 X-3.9541Y2.1746 X-3.485Y2.3423 X-3.0959Y2.5 X-3.485Y2.6577 X-3.9541Y2.8254 X-4.4187Y2.9417 X-4.8943Y3.0108 X-4.9595Y3.0139 Y1.9861 X-4.8943Y1.9892 X-4.6965Y2.0179 X-4.6634Y1.7903 X-4.3742Y1.8324 X-3.8873Y1.9542 X-3.403Y2.1274 X-2.9041Y2.3296 X-2.8881Y2.3357 X-2.4378Y2.5 X-2.8881Y2.6643 X-2.9041Y2.6704 X-3.403Y2.8726 X-3.8873Y3.0458 X-4.3742Y3.1676 X-4.8722Y3.24 X-5.1895Y3.2551 Y1.7449 X-4.8722Y1.76 X-4.6634Y1.7903 X-4.6303Y1.5627 X-4.3296Y1.6064 X-3.8205Y1.7338 X-3.3211Y1.9124 X-2.8177Y2.1164 X-2.8093Y2.1196 X-2.7971Y2.1241 X-2.7966Z0.1913 X-2.3009Y2.3052 X-2.3004Z0.005 X-2.2938Y2.3077 X-2.276Y2.3135 X-2.2621Y2.3175 X-2.2616Z0.1913 X-2.0247Y2.3849 X-2.0242Z0.005 X-2.0111Y2.3887 X-1.9946Y2.3928 X-1.9838Y2.3951 Z0.1913 X-1.7359Y2.448 Z0.005 X-1.725Y2.4503 X-1.7058Y2.4536 X-1.6971Y2.4548 Z0.1913 X-1.4419Y2.4891 Z0.005 X-1.4332Y2.4903 X-1.4111Y2.4923 X-1.4046 Z0.1913 X-1.2478Y2.5 X-1.4041Y2.5074 Z0.005 X-1.4111 X-1.4332Y2.5097 X-1.4411Y2.5108 Z0.1913 X-1.6968Y2.5452 Z0.005 X-1.7058Y2.5464 X-1.725Y2.5497 X-1.7355Y2.552 X-1.736Z0.1913 X-1.9834Y2.6048 Z0.005 X-1.9946Y2.6072 X-2.0111Y2.6113 X-2.0244Y2.6151 Z0.1913 X-2.2617Y2.6825 Z0.005 X-2.276Y2.6865 X-2.2938Y2.6923 X-2.3006Y2.6948 X-2.3011Z0.1913 X-2.7966Y2.8757 X-2.7971Z0.005 X-2.8093Y2.8804 X-2.8177Y2.8836 X-3.3211Y3.0876 X-3.8205Y3.2662 X-4.3296Y3.3936 X-4.8502Y3.4692 X-5.3811Y3.4945 X-5.4195 Y1.5055 X-5.3811 X-4.8502Y1.5308 X-4.6304Y1.5627 G00Z0.505 X-4.7295Y2.2456 G01Z-0.245 X-4.4633Y2.2842 X-4.0209Y2.395 X-3.7272Y2.5 X-4.0209Y2.605 X-4.4633Y2.7158 X-4.7295Y2.7544 Y2.2457 X-4.6964Y2.018 X-4.4187Y2.0583 X-3.9541Y2.1746 X-3.485Y2.3423 X-3.0959Y2.5 X-3.485Y2.6577 X-3.9541Y2.8254 X-4.4187Y2.9417 X-4.8943Y3.0108 X-4.9595Y3.0139 Y1.9861 X-4.8943Y1.9892 X-4.6965Y2.0179 X-4.6634Y1.7903 X-4.3742Y1.8324 X-3.8873Y1.9542 X-3.403Y2.1274 X-2.9041Y2.3296 X-2.8881Y2.3357 X-2.4378Y2.5 X-2.8881Y2.6643 X-2.9041Y2.6704 X-3.403Y2.8726 X-3.8873Y3.0458 X-4.3742Y3.1676 X-4.8722Y3.24 X-5.1895Y3.2551 Y1.7449 X-4.8722Y1.76 X-4.6634Y1.7903 X-4.6303Y1.5627 X-4.3296Y1.6064 X-3.8205Y1.7338 X-3.3211Y1.9124 X-2.8177Y2.1164 X-2.8093Y2.1196 X-2.7971Y2.1241 X-2.7966Z0.1275 X-2.3009Y2.3052 X-2.3004Z-0.245 X-2.2938Y2.3077 X-2.276Y2.3135 X-2.2621Y2.3175 X-2.2616Z0.1275 X-2.0247Y2.3849 X-2.0242Z-0.245 X-2.0111Y2.3887 X-1.9946Y2.3928 X-1.9838Y2.3951 Z0.1275 X-1.7359Y2.448 Z-0.245 X-1.725Y2.4503 X-1.7058Y2.4536 X-1.6971Y2.4548 Z0.1275 X-1.4419Y2.4891 Z-0.245 X-1.4332Y2.4903 X-1.4111Y2.4923 X-1.4046 Z0.1275 X-1.2478Y2.5 X-1.4041Y2.5074 Z-0.245 X-1.4111 X-1.4332Y2.5097 X-1.4411Y2.5108 Z0.1275 X-1.6968Y2.5452 Z-0.245 X-1.7058Y2.5464 X-1.725Y2.5497 X-1.7355Y2.552 X-1.736Z0.1275 X-1.9834Y2.6048 Z-0.245 X-1.9946Y2.6072 X-2.0111Y2.6113 X-2.0244Y2.6151 Z0.1275 X-2.2617Y2.6825 Z-0.245 X-2.276Y2.6865 X-2.2938Y2.6923 X-2.3006Y2.6948 X-2.3011Z0.1275 X-2.7966Y2.8757 X-2.7971Z-0.245 X-2.8093Y2.8804 X-2.8177Y2.8836 X-3.3211Y3.0876 X-3.8205Y3.2662 X-4.3296Y3.3936 X-4.8502Y3.4692 X-5.3811Y3.4945 X-5.4195 Y1.5055 X-5.3811 X-4.8502Y1.5308 X-4.6304Y1.5627 G00Z0.505 X-4.7295Y2.2456 G01Z-0.495 X-4.4633Y2.2842 X-4.0209Y2.395 X-3.7272Y2.5 X-4.0209Y2.605 X-4.4633Y2.7158 X-4.7295Y2.7544 Y2.2457 X-4.6964Y2.018 X-4.4187Y2.0583 X-3.9541Y2.1746 X-3.485Y2.3423 X-3.0959Y2.5 X-3.485Y2.6577 X-3.9541Y2.8254 X-4.4187Y2.9417 X-4.8943Y3.0108 X-4.9595Y3.0139 Y1.9861 X-4.8943Y1.9892 X-4.6965Y2.0179 X-4.6634Y1.7903 X-4.3742Y1.8324 X-3.8873Y1.9542 X-3.403Y2.1274 X-2.9041Y2.3296 X-2.8881Y2.3357 X-2.4378Y2.5 X-2.8881Y2.6643 X-2.9041Y2.6704 X-3.403Y2.8726 X-3.8873Y3.0458 X-4.3742Y3.1676 X-4.8722Y3.24 X-5.1895Y3.2551 Y1.7449 X-4.8722Y1.76 X-4.6634Y1.7903 X-4.6303Y1.5627 X-4.3296Y1.6064 X-3.8205Y1.7338 X-3.3211Y1.9124 X-2.8177Y2.1164 X-2.8093Y2.1196 X-2.7971Y2.1241 X-2.7966Z0.0638 X-2.3009Y2.3052 X-2.3004Z-0.495 X-2.2938Y2.3077 X-2.276Y2.3135 X-2.2621Y2.3175 X-2.2616Z0.0638 X-2.0247Y2.3849 X-2.0242Z-0.495 X-2.0111Y2.3887 X-1.9946Y2.3928 X-1.9838Y2.3951 Z0.0638 X-1.7359Y2.448 Z-0.495 X-1.725Y2.4503 X-1.7058Y2.4536 X-1.6971Y2.4548 Z0.0638 X-1.4419Y2.4891 Z-0.495 X-1.4332Y2.4903 X-1.4111Y2.4923 X-1.4046 Z0.0638 X-1.2478Y2.5 X-1.4041Y2.5074 Z-0.495 X-1.4111 X-1.4332Y2.5097 X-1.4411Y2.5108 Z0.0638 X-1.6968Y2.5452 Z-0.495 X-1.7058Y2.5464 X-1.725Y2.5497 X-1.7355Y2.552 X-1.736Z0.0638 X-1.9834Y2.6048 Z-0.495 X-1.9946Y2.6072 X-2.0111Y2.6113 X-2.0244Y2.6151 Z0.0638 X-2.2617Y2.6825 Z-0.495 X-2.276Y2.6865 X-2.2938Y2.6923 X-2.3006Y2.6948 X-2.3011Z0.0638 X-2.7966Y2.8757 X-2.7971Z-0.495 X-2.8093Y2.8804 X-2.8177Y2.8836 X-3.3211Y3.0876 X-3.8205Y3.2662 X-4.3296Y3.3936 X-4.8502Y3.4692 X-5.3811Y3.4945 X-5.4195 Y1.5055 X-5.3811 X-4.8502Y1.5308 X-4.6304Y1.5627 G00Z0.505 X-4.7295Y2.2456 G01Z-0.745 X-4.4633Y2.2842 X-4.0209Y2.395 X-3.7272Y2.5 X-4.0209Y2.605 X-4.4633Y2.7158 X-4.7295Y2.7544 Y2.2457 X-4.6964Y2.018 X-4.4187Y2.0583 X-3.9541Y2.1746 X-3.485Y2.3423 X-3.0959Y2.5 X-3.485Y2.6577 X-3.9541Y2.8254 X-4.4187Y2.9417 X-4.8943Y3.0108 X-4.9595Y3.0139 Y1.9861 X-4.8943Y1.9892 X-4.6965Y2.0179 X-4.6634Y1.7903 X-4.3742Y1.8324 X-3.8873Y1.9542 X-3.403Y2.1274 X-2.9041Y2.3296 X-2.8881Y2.3357 X-2.4378Y2.5 X-2.8881Y2.6643 X-2.9041Y2.6704 X-3.403Y2.8726 X-3.8873Y3.0458 X-4.3742Y3.1676 X-4.8722Y3.24 X-5.1895Y3.2551 Y1.7449 X-4.8722Y1.76 X-4.6634Y1.7903 X-4.6303Y1.5627 X-4.3296Y1.6064 X-3.8205Y1.7338 X-3.3211Y1.9124 X-2.8177Y2.1164 X-2.8093Y2.1196 X-2.7971Y2.1241 X-2.7966Z0. X-2.3009Y2.3052 X-2.3004Z-0.745 X-2.2938Y2.3077 X-2.276Y2.3135 X-2.2621Y2.3175 X-2.2616Z0. X-2.0247Y2.3849 X-2.0242Z-0.745 X-2.0111Y2.3887 X-1.9946Y2.3928 X-1.9838Y2.3951 Z0. X-1.7359Y2.448 Z-0.745 X-1.725Y2.4503 X-1.7058Y2.4536 X-1.6971Y2.4548 Z0. X-1.4419Y2.4891 Z-0.745 X-1.4332Y2.4903 X-1.4111Y2.4923 X-1.4046 Z0. X-1.2478Y2.5 X-1.4041Y2.5074 Z-0.745 X-1.4111 X-1.4332Y2.5097 X-1.4411Y2.5108 Z0. X-1.6968Y2.5452 Z-0.745 X-1.7058Y2.5464 X-1.725Y2.5497 X-1.7355Y2.552 X-1.736Z0. X-1.9834Y2.6048 Z-0.745 X-1.9946Y2.6072 X-2.0111Y2.6113 X-2.0244Y2.6151 Z0. X-2.2617Y2.6825 Z-0.745 X-2.276Y2.6865 X-2.2938Y2.6923 X-2.3006Y2.6948 X-2.3011Z0. X-2.7966Y2.8757 X-2.7971Z-0.745 X-2.8093Y2.8804 X-2.8177Y2.8836 X-3.3211Y3.0876 X-3.8205Y3.2662 X-4.3296Y3.3936 X-4.8502Y3.4692 X-5.3811Y3.4945 X-5.4195 Y1.5055 X-5.3811 X-4.8502Y1.5308 X-4.6304Y1.5627 G00Z0.505 |
| Okay, I really need to move on so I edited the G-code. If you have a better solution please let me know so that I can learn and do it better next time ![]() Here is the edited G code... Code: // roughing right Z0.1 X0.33Y1.505 G01Z-0.2483F25 X0.3698 X1.9343Y1.735 X0.33 Y1.965 X2.5601 X2.5939Y1.9782 //Z0. //X3.1488Y2.195 X2.9488Y2.195 X3.1356 //Z-0.2483 X0.33 Y2.425 X3.897 //X3.8975Z0. //X3.909 X3.709 X3.9064Y2.4269 //Z-0.2483 X3.5919Y2.6513 //Z0. //X3.5866Y2.655 X3.3866Y2.655 X3.5794 //Z-0.2483 X0.33 Y2.885 X2.93 //Z0. X2.9194Y2.8893 //Z-0.2483 X2.3536Y3.115 X0.33 Y3.345 X1.6164 X0.3698Y3.495 X0.33 G00Z0.1 Y1.505 G01Z-0.4967 X0.3698 X1.9343Y1.735 X0.33 Y1.965 X2.5601 X2.5939Y1.9782 //Z0. //X3.1488Y2.195 X2.9488Y2.195 X3.1356 //Z-0.4967 X0.33 Y2.425 X3.897 //X3.8975Z0. //X3.909 X3.709 X3.9064Y2.4269 //Z-0.4967 X3.5919Y2.6513 //Z0. //X3.5866Y2.655 X3.3866Y2.655 X3.5794 //Z-0.4967 X0.33 Y2.885 X2.93 //Z0. X2.9194Y2.8893 //Z-0.4967 X2.3536Y3.115 X0.33 Y3.345 X1.6164 X0.3698Y3.495 X0.33 G00Z0.1 Y1.505 G01Z-0.745 X0.3698 X1.9343Y1.735 X0.33 Y1.965 X2.5601 X2.5939Y1.9782 //Z0. //X3.1488Y2.195 X2.9488Y2.195 X3.1356 //Z-0.745 X0.33 Y2.425 X3.897 //X3.8975Z0. //X3.909 X3.709 X3.9064Y2.4269 //Z-0.745 X3.5919Y2.6513 //Z0. //X3.5866Y2.655 X3.3866Y2.655 X3.5794 //Z-0.745 X0.33 Y2.885 X2.93 //Z0. X2.9194Y2.8893 //Z-0.745 X2.3536Y3.115 X0.33 Y3.345 X1.6164 X0.3698Y3.495 X0.33 G00Z0.1 |
| The code is running (there might be very minor changes I made directly on Mach3, but no more than one or two). The problem now is that my Z axis stepper came loose during the testing and I had to stop ![]() If you are following this thread here is the code I'm testing with and attached is the cad file ![]() Code: ;1/4 drill bit for thru holes ;make sure to zero Z on stock surface M5 M9 ;G0 G28 G91 Z0. G28 G91 Z0. T1 M6 S1000 M3 G90 G54 X0. Y0. ;G43 H1 D1 Z3. M8 ; pecked holes G73X-0.875Y-3.75Z-1.3R0.1Q0.5F20 X-2.5Y-3.825 X-4.125Y-3.9 Y-1.1 X-2.5Y-1.175 X-0.875Y-1.25 X1.625Y-1.1 X3.25Y-1.175 X4.875Y-1.25 Y-3.75 X3.25Y-3.825 X1.625Y-3.9 G80 ;1/2 end mill for countersinking and all milling ;make sure to zero Z on stock surface M5 M9 ;G0 G28 G91 Z0. G28 G91 Z0. T2 M6 S1000 M3 G90 G54 X0. Y0. ;G43 H2 D2 Z0. M8 G81X-0.875Y-3.75 Z-.25R0.1F25 X-2.5Y-3.825 X-4.125Y-3.9 Y-1.1 X-2.5Y-1.175 X-0.875Y-1.25 X1.625Y-1.1 X3.25Y-1.175 X4.875Y-1.25 Y-3.75 X3.25Y-3.825 X1.625Y-3.9 G80 ;rought right Z0.1 X0.33Y-1.505 G01Z-0.2483F25 X0.3698 X1.9343Y-1.735 X0.33 Y-1.965 X2.5601 X2.5939Y-1.9782 ;Z0. ;X3.1488Y-2.195 X2.9488Y-2.195 X3.1356 ;Z-0.2483 X0.33 Y-2.425 X3.897 ;X3.8975Z0. ;X3.909 X3.709 X3.9064Y-2.4269 ;Z-0.2483 X3.5919Y-2.6513 ;Z0. ;X3.5866Y-2.655 X3.3866Y-2.655 X3.5794 ;Z-0.2483 X0.33 Y-2.885 X2.93 ;Z0. X2.9194Y-2.8893 ;Z-0.2483 X2.3536Y-3.115 X0.33 Y-3.345 X1.6164 X0.3698Y-3.495 X0.33 G00Z0.1 Y-1.505 G01Z-0.4967 X0.3698 X1.9343Y-1.735 X0.33 Y-1.965 X2.5601 X2.5939Y-1.9782 ;Z0. ;X3.1488Y-2.195 X2.9488Y-2.195 X3.1356 ;Z-0.4967 X0.33 Y-2.425 X3.897 ;X3.8975Z0. ;X3.909 X3.709 X3.9064Y-2.4269 ;Z-0.4967 X3.5919Y-2.6513 ;Z0. ;X3.5866Y-2.655 X3.3866Y-2.655 X3.5794 ;Z-0.4967 X0.33 Y-2.885 X2.93 ;Z0. X2.9194Y-2.8893 ;Z-0.4967 X2.3536Y-3.115 X0.33 Y-3.345 X1.6164 X0.3698Y-3.495 X0.33 G00Z0.1 Y-1.505 G01Z-0.745 X0.3698 X1.9343Y-1.735 X0.33 Y-1.965 X2.5601 X2.5939Y-1.9782 ;Z0. ;X3.1488Y-2.195 X2.9488Y-2.195 X3.1356 ;Z-0.745 X0.33 Y-2.425 X3.897 ;X3.8975Z0. ;X3.909 X3.709 X3.9064Y-2.4269 ;Z-0.745 X3.5919Y-2.6513 ;Z0. ;X3.5866Y-2.655 X3.3866Y-2.655 X3.5794 ;Z-0.745 X0.33 Y-2.885 X2.93 ;Z0. X2.9194Y-2.8893 ;Z-0.745 X2.3536Y-3.115 X0.33 Y-3.345 X1.6164 X0.3698Y-3.495 X0.33 G00Z0.1 ;profile right X1.625Y-3.9 X-0.0065Y-1.8536 G01Z0.F15 X0.347Y-1.5 X0.369 X0.9003Y-1.5253 X1.4215Y-1.601 X1.9311Y-1.7286 X2.4309Y-1.9073 X2.9344Y-2.1113 G02X2.9426Y-2.1145I0.0939J0.2317 G01X3.4581Y-2.3026 G02X3.4755Y-2.3082I0.0857J0.2349 G01X3.7404Y-2.3834 G02X3.7565Y-2.3874I0.0683J0.2405 G01X4.0261Y-2.4449 G02X4.0449Y-2.4482I0.0522J0.2445 G01X4.3176Y-2.4849 G02X4.3392Y-2.4868I0.0333J0.2478 G01X4.6132Y-2.4997 G02X4.625I0.0118J0.2497 X4.6132Y-2.5003I0.J-0.25 G01X4.3392Y-2.5132 G02X4.3176Y-2.5151I0.0117J-0.2497 G01X4.0449Y-2.5518 G02X4.0261Y-2.5551I0.0334J-0.2478 G01X3.7565Y-2.6126 G02X3.7404Y-2.6166I0.0522J-0.2445 G01X3.4755Y-2.6918 G02X3.4581Y-2.6974I0.0683J-0.2405 G01X2.9426Y-2.8855 G02X2.9344Y-2.8887I0.0857J-0.2349 G01X2.4309Y-3.0927 X1.9311Y-3.2714 X1.4215Y-3.399 X0.9003Y-3.4747 X0.369Y-3.5 X0.325 Y-1.5 X0.347 X0.7006Y-1.8536 G00Z0.1 ;finish bottom X0.33Y-1.505 G01Z-0.75F15 X0.3698 X1.9343Y-1.735 X0.33 Y-1.965 X2.5601 X2.5939Y-1.9782 ;Z0. ;X3.1488Y-2.195 X2.9488Y-2.195 X3.1356 ;Z-0.75 X0.33 Y-2.425 X3.897 ;X3.8975Z0. ;X3.909 X3.709 X3.9064Y-2.4269 ;Z-0.75 X3.5919Y-2.6513 ;Z0. ;X3.5866Y-2.655 X3.3866Y-2.655 X3.5794 ;Z-0.75 X0.33 Y-2.885 X2.93 ;Z0. X2.9194Y-2.8893 ;Z-0.75 X2.3536Y-3.115 X0.33 Y-3.345 X1.6164 X0.3698Y-3.495 X0.33 G00Z0.1 ;end of test G00 X0 Y0 Z0 Is this really the way it is or am I trying too hard? Thanks! |
| Okay, I made it into subroutines... Problem is either my subroutines are messed up of BobCad does not understand subroutines. Simulation, tool path representation... all gone ![]() Will need to wait a day or two till I have time to check the Z axis to run it on the machine on air and then on Styrofoam or something cheap and forgiving (not sure what). ; through holes with peck drilling M5 M9 G00 X0 Y0 Z0 T1 M06 (0.25 drill bit, 1000 RPM, zero Z on workpiece height) M3 S1000 M8 G73X-0.875Y-3.75Z-1.3R0.1Q0.5F20 M98 P6 G80 ; countersunk holes with spot drilling M5 M9 G00 X0 Y0 Z4 T1 M06 (0.50 3 flute end mill, 1000 RPM, zero Z on workpiece height) M3 S1000 M8 G81X-0.875Y-3.75 Z-.25R0.1F25 M98 P6 G80 ; pocketing and profile M5 M9 T1 M06 (no tool change, manualy set RPM to 2500 RPM) M3 S2500 M8 G52 X0 Y0 (right pocket) M98 P1 G52 X-5.75 Y0 (left pocket) M98 P1 ; missing external profile ; done! G00 G93 X0 Y0 Z0 (go to machine zero) M30 (finish) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ; subroutine to do pocket ; does provide Z clearance ; does reset G92 O1 G52 Z0 (pass 1 - rough) G00 Z0.1 M98 P2 G52 Z-0.25 (pass 2 - rough) G00 Z0.1 M98 P2 G52 Z-0.495 (pass 3 - rough) G00 Z0.1 M98 P2 G52 Z-0.5 (pass 4 - finish) G00 Z0.1 M98 P3 G52 Z0 (finish side) G00 Z0.1 M98 P5 G52 X0 Y0 Z0 (reset G52) G00 Z0.1 (rapid plane) M99 ; subroutine to remove one rough pass on pocket ; assumes no responsability for Z clearance O2 X0.33Y-1.505 G01Z-0.25F25 (plunges -0.25 in relation to G52, sets roughing IPM) M98 P4 M99 ; subroutine to finish pocket bottom ; assumes no responsability for Z clearance O3 X0.33Y-1.505 G01Z-0.25F15 (plunges -0.25 in relation to G52, sets finishing IPM) M98 P4 M99 ; helper subroutine to remove one pass on pocket ; assumes no responsability for Z clearance O4 X0.3698 X1.9343Y-1.735 X0.33 Y-1.965 X2.5601 X2.5939Y-1.9782 X2.9488Y-2.195 X3.1356 X0.33 Y-2.425 X3.897 X3.709 X3.9064Y-2.4269 X3.5919Y-2.6513 X3.3866Y-2.655 X3.5794 X0.33 Y-2.885 X2.93 X2.9194Y-2.8893 X2.3536Y-3.115 X0.33 Y-3.345 X1.6164 X0.3698Y-3.495 X0.33 M99 ; subroutine to finish pocket side ; assumes no responsability for Z clearance O5 X0.33Y-1.505 G01Z-0.75F15 (plunge -0.75 in relation to G52, sets finishing IPM) X0.347Y-1.5 X0.369 X0.9003Y-1.5253 X1.4215Y-1.601 X1.9311Y-1.7286 X2.4309Y-1.9073 X2.9344Y-2.1113 G02X2.9426Y-2.1145I0.0939J0.2317 G01X3.4581Y-2.3026 G02X3.4755Y-2.3082I0.0857J0.2349 G01X3.7404Y-2.3834 G02X3.7565Y-2.3874I0.0683J0.2405 G01X4.0261Y-2.4449 G02X4.0449Y-2.4482I0.0522J0.2445 G01X4.3176Y-2.4849 G02X4.3392Y-2.4868I0.0333J0.2478 G01X4.6132Y-2.4997 G02X4.625I0.0118J0.2497 X4.6132Y-2.5003I0.J-0.25 G01X4.3392Y-2.5132 G02X4.3176Y-2.5151I0.0117J-0.2497 G01X4.0449Y-2.5518 G02X4.0261Y-2.5551I0.0334J-0.2478 G01X3.7565Y-2.6126 G02X3.7404Y-2.6166I0.0522J-0.2445 G01X3.4755Y-2.6918 G02X3.4581Y-2.6974I0.0683J-0.2405 G01X2.9426Y-2.8855 G02X2.9344Y-2.8887I0.0857J-0.2349 G01X2.4309Y-3.0927 X1.9311Y-3.2714 X1.4215Y-3.399 X0.9003Y-3.4747 X0.369Y-3.5 X0.325 Y-1.5 X0.347 X0.7006Y-1.8536 M99 ; subroutine to drill holes ; assumes modal G73 or G81 O6 X-2.5Y-3.825 X-4.125Y-3.9 Y-1.1 X-2.5Y-1.175 X-0.875Y-1.25 X1.625Y-1.1 X3.25Y-1.175 X4.875Y-1.25 Y-3.75 X3.25Y-3.825 X1.625Y-3.9 M99 Last edited by Ed from NY; 06-26-2009 at 01:09 AM. |
| Weird, I also tried the CNC Simulator (http://www.cncsimulator.com/) and they do not support subroutines either. So I guess if you start touching up code in that way it will be between you and your text editor. Last edited by Ed from NY; 06-26-2009 at 09:07 AM. |
#10
| Ed, I think you are trying too hard on this project. 1) If you are having the tool scuff up the wall on the pocket. Offset the pocket wall to leave stock for a finish path. .100 or so. You could just do this in the pocket tool path feature there is a setting for stock left for finishing. 2) In order to get a nice and clean wall you need to run a finish tool on just the profile of the wall. |
#11
![]() Above I'm using the finishing tool as the same end mill just with a slower feed (F15 instead of F25). If I want to use the same end mill (because I do not have another) can I do it that way or should I up the RPM as well? BTW, the reason why I chose to change only the feed is because the spindle control on my mill is not working from gcode , but I could rearrange things so that the roughing takes place in both pockets, then I manually change the RPM, and then do the finishing on both pockets if that would work a bit better. |
#12
| Ed, I think you would find this to be much more simple to work with if you draw it in 2D. You can use the same tool for both operations, but in reality then you're finishing the entire part. I would suggest investing in some roughers. You will be able to run much higher feed rates. |
| Need Help!- Please help me with this piece | serandre | Mastercam | 3 | 08-03-2009 01:01 PM |
| Need Help!- What process for this piece? | fer_mayrl | Bending, Forging,Extrusion... | 0 | 03-29-2009 01:59 PM |
| Advice on how to do this piece | Swami | General Metal Working Machines | 13 | 10-20-2004 11:37 AM |
| a waterblock, a piece of art.. what do you think | Ferenczyg | Computers and Networking | 9 | 04-24-2004 12:30 PM |
