Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 06-23-2009, 12:33 PM
1234567 is on a distinguished road
v23 post
why wont my predator editor run a simulation when i post a program useing the osp-u100m post.It works for my fanuc post.and it does include a predator header at the start of the program.It will draw out the stock but no tool path.Also im useing v-23 pro
Old 06-23-2009, 01:53 PM
BurrMan is on a distinguished road
Can you post a simple sample of the code it outputs?
Old 06-23-2009, 02:14 PM
here is the sample prog
(BEGIN PREDATOR NC HEADER)
(MACH_FILE=OKUMA - 3XVMILL.MCH)
(MTOOL T17 S1 D+4. H+5. A+0. C+0. DIAM_OFFSET 17 = +2.)
(MTOOL T2 S1 D+1. H+5. A+0. C+0. DIAM_OFFSET 2 = +.5)
(MTOOL T3 S1 D+1.01 H+5. A+0. C+0. DIAM_OFFSET 3 = +.505)
(SBOX X-1.1811 Y-1.7715 Z-1. L+2.9622 W+3.543 H+1.)
(END PREDATOR NC HEADER)
$A.MIN%
(PROGRAM NUMBER: 100)
(PROGRAM NAME: 23526860.NC)
(POST: OKUMA OSP-U100M)
(DATE: TUE. 06/23/2009)
(TIME: 02:13PM)
G00 G90 G80 G40 G20 G17
(JOB 1 FACING)
(MY OPERATION NAME)
VC1= 17 VC2= 02
CALL OTOOL
G15 H1
G56 H17 D17 S380 M03
X+0. Y+6.1215
Z+.1 M08
G01 Z+0. F+.1123
Y-4.0785 F+6.
G00 Z+.1
(JOB 2 CONTOUR)
(MY OPERATION NAME)
N01 VC1= 17 VC2= 03
CALL OTOOL
G15 H1
G56 H02 D02 S320 M03
X+1.7811 Y+0.
Z+.1 M08
G01 Z-.9 F+.4492
Y+.6 F+3.
G17 G03 X+1.1811 Y+0. I+0. J-.6
G02 X+.9692 Y-.675 I-1.1811 J+0.
G01 X+.3231 Y-1.6028
G02 X-.3231 Y-1.6028 I-.3231 J+.225
G01 X-.9692 Y-.675
G02 X-.9692 Y+.675 I+.9692 J+.675
G01 X-.3231 Y+1.6028
G02 X+.3231 Y+1.6028 I+.3231 J-.225
G01 X+.9692 Y+.675
G02 X+1.1811 Y+0. I-.9692 J-.675
G03 X+1.7811 Y-.6 I+.6 J+0.
G01 Y+0.
G00 Z+.1
(JOB 2 CONTOUR)
(MY OPERATION NAME)
N02 VC1= 17 VC2= 17
CALL OTOOL
G15 H1
G56 H03 D03 S320 M03
X+1.7811 Y+0.
Z+.1 M08
G01 Z-.9 F+.8067
Y+.6 F+3.
G01 X-.9692 Y-.675
G01 X+.9692 Y+.675
G01 Y+0.
G00 Z+.1
M09
T17 M06
M02
Old 06-23-2009, 02:26 PM
simulation
if i turn off solid and animation i can see back plotting but its not very good.
Old 06-23-2009, 02:36 PM
I may not be too much help here. It appears to me that the tool info is missing for the feature cuts. (The default predator needed info).
I believe you may want to go to the edit menu and click template. (Make a new template from one of the defaults) then set some of those parameters to match the code your outputting...Toolchanges and whatnot.
I'm not very good in this area and may be wrong. Maybe somebody else can chime in here that can be more help.
Old 06-23-2009, 02:40 PM
post
i check that out thanks
Old 06-25-2009, 08:54 AM
Allen123's Avatar
Allen123 is on a distinguished road
You are most likely going to need to edit your RVP file.
The RVP file is to the simulation as a post file is to your machine.
The code you posted doesn't use a T# M06 tool call. So predator is not seeing the tool calls because it's RVP file is looking for T# M06 ....
Old 06-25-2009, 03:17 PM
Are we talking "Backplotting the code in Editor"? Thats what I thought. If we are talking rvp cheat to the VCNC program, then, thats a bit much
Need post Delcam PowerMILL post for Hardinge VMC 600 II with Fanuc Series oi-MB littlem Post Processor Files 0 10-26-2006 04:59 PM
