| BobCad-Cam Discuss all BobCad software here. |
I have a part done in Solidworks, opened in BobCAD V23. It ends up being a very long file, so I am successfully using DNC to transfer it to the CNC88HS control... I noticed however that the feed rate is SUPPPERRR SLOOOOWWW...something like F1.436 or close to that... The material is Aluminum... It is a rough cut... It doesn't seem to be using the default value....?? Do I need to calibrate the feeds between the machine and the software? I am using Format 2, and the CNC88 post... Thanks!! |
| I know nothing about BCC but I CAN tell you for sure that your issue is with BCC or its post processor has nothing to do with the machine or "calibration of transfer"
| There should be a way to Over Ride the Default Feeds and Speeds. Have you checked your Help Files?
| MBX5, What are the feeds that are being output in your code? Chances are that the default feeds and speeds are more conservative than you need. You can do one of three things, 1. Edit the Feeds and speeds per operation. This would entail editing each operation. You do not have to re-compute the paths. Once in the operation, go to the tool page(s) and click the Manual button above the speeds and feeds. Then you can edit the feed rates. 2. Edit the Cutting Conditions. This one is a rather cumbersome method. Before editing these, search the Help Files for Cutting Conditions. You should be able to find the information needed for adjusting them in that topic. 3. Do a Find and Replace for the slow feedrates. Regards |
| Try this. Before you generate toolpath, go to your material selection and select ANYTHING other than aluminum. Select ok then go back and re-select aluminum. Generate toolpath and post. If you ever change geometry or the toolpath setting, or close the file and re-open it, change the material and accept it, then change it back to the desired material, re-compute the toolpath and post. Your feeds should be appropriate. |
| GibbsCam to Fadal 4020 | andrejculk | Post Processor Files | 10 | 08-18-2009 08:32 AM |
| CNC88HS file loading question | MBX5 | Fadal | 8 | 06-13-2009 08:20 PM |
| Purchased a used Fadal 4020 - shipping question | MBX5 | Fadal | 7 | 05-26-2009 07:38 AM |
| FADAL VMC 4020 | dmac88 | Fadal | 7 | 05-18-2009 02:45 PM |
| How do I tell the age of a FADAL 4020? | Rickady | Fadal | 8 | 07-10-2007 06:02 AM |
