Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 05-26-2009, 08:43 AM
lynn mynatt is on a distinguished road
Lathe Post giving crazy numbers
when I post to out Haas lathe, the post...at the very end shows some crazy LARGE dimensions for I and J in the circular moves. This is on a part 2" dia. with a couple of grooves 1/2" wide and 1/8" deep with radii in the corners. I've only pasted the section of code where the problem shows up. Just wandering if anyone has seen this before and what did you do the fix it?
(JOB 1 GROOVE CYCLE )
(TOOL #27 1/4 OD ANVIL )
N817 G0 X1.2213 Z-4.004
N818 G42 G1 X.9788 Z-4.0015 F5.
N819 G3 X.974 Z-3.9967 J-.0012 I.0036
N820 G1 Z-2.6268
N821 G2 X.8694 Z-2.5033 J-.1269 I-.0014
N822 G1 X.8671 Z-2.5025
N823 G2 X.7865 Z-2.4985 J-.0624 I-.4428
N824 G1 Z-2.2642
N825 G0 X1.2213
N826 Z-1.9913
N827 X.974
N828 G1 Z-2.117
N829 G3 X.8633 Z-2.25 J-.1247 I-.0089
N830 G2 X.7868 Z-2.2516 J-.0303 I-.3798
N831 G3 X.7865 Z-2.2532 J.0018 I-.0012
N832 G0 X1.2213
N833 Z-2.0023
N834 X.974
N835 G2 X.973 Z-1.1174 J-201.2139 I.2164
N836 G1 X.9726 Z-1.1134
N837 G2 X.8679 Z-1.0028 J-.1257 I-.0142
N838 X.7865 Z-.9988 J-.0605 I-.4006
N839 G1 Z-.7645
N840 G0 X1.2213
N841 Z-.4908
N842 X.9741
N843 G1 Z-.6092
N844 G3 X.9255 Z-.7254 J-.1324 I-.013
N845 X.8682 Z-.7495 J-.0695 I.0853
N846 G1 X.7915 Z-.7511
N847 G3 X.7865 Z-.7535 J-.0023 I-.0017
N848 G0 X1.2213
N849 Z-.5018
N850 X.9741
N851 G2 X.9729 Z-.1162 J-37.0107 I.0827
N852 G1 X.9726 Z-.113
N853 G2 X.8691 Z-.0032 J-.1257 I-.0147
N854 G1 X.8668 Z-.0024
N855 G2 X.8528 Z-.0008 J-.0099 I-.0247
N856 G0 X1.2213
N857 Z.0016
N858 X1.1224
N859 G2 X.8528 Z-.0008 J18431.3971 I-2066618.8766
N860 G0 X5.
N861 Z5.
(TOOL #1 80 DEG. 1/64 ROUGH TURNING )
N862 G28
N863 T0101
N864 G54 G00 X1.3108 Z.0029 M08
N865 G96 S500 M03
N866 Z5.
N867 X5.
N868 G97
N869 G30 U0 W0
N870 M1
N871 G70 P872Q
Old 05-26-2009, 01:48 PM
Allen123's Avatar
Allen123 is on a distinguished road
awesome!
Old 05-26-2009, 10:33 PM
paul gibson is on a distinguished road
Lynn,
Have not messed w/ BobCad since the Demo V-17 days. But does it give an option to use an R value as opposed to the I/K/J values? If so, might toggle that on and see if you get better results.
Regards,
Paul
Old 05-27-2009, 09:01 AM
If there is a setting for R values, I can't find it. Oddly enough, it seems to run ok in verify mode, but when i send it to the machine, it freaks out. I'll call Bobcad and see what they can do, it's my understanding that they will work with post issues and I'm pretty sure thats where the problem is.
Thanks for the help though!
Old 05-27-2009, 03:02 PM
The One is on a distinguished road
Open the post in a text editor.
Go to line 242. it should look like this: 242. Arc center a=absolute, b=incremental, d=unsigned inc., e=radius? b
Change the letter at the end to e and save the file.
Then repost. You should now get Radius output.
I have seen these occur as well. It will most commonly happen when you have the Collision detection turned on.
Regards
Old 05-28-2009, 12:25 PM
The One,
If I understand you correctly, I was to change the b to an e ? Line 242 was exactly as you said, but changing the letter to an e didn't fix the problem unless I'm doing something wrong. I did repost and I'll try again, but I'm pretty sure I got it right.
And thanks for the help.
Note: I double checked and the "e" is saved to the post. I also tried with collision detection off. THAT worked! Now, my question is.... am I going to crash something without the detection?
Old 05-28-2009, 07:12 PM
mmc005 is on a distinguished road
Lynn,
I have seen alot of issues with the collision detection on, I always leave it off. You should not crash as long as you know that your tool is the correct tool for the operation that your doing.
For example, you need to use a grooving tool for a deep groove and not a standard turning tool. The turning tool will "crash" trying to get into the groove while the grooving tool is designed to be able to cut deep grooves without crashing.
Old 05-29-2009, 07:02 AM
thx mmc, I haven't got the chance to run the program yet, somebody else has the machine tied up (it has conversational programming as well). The simulation looks good though and the large radii numbers are gone in the post.
Thanks for the help EVERYBODY.
Old 05-29-2009, 07:32 AM
Lynn,
Try changing the letter to a capital "E". Sometimes that is the problem with converting over to radius.
The other option is to do a find and replace in the post. Replace all instance of "rcenter" with "arc_center". There are many variables in the posting engine that do the same thing, only slightly different, and this could be the cause to the lack of R values.
As far as crashing, you really have to take the geometry into consideration. If there are areas on the part that you could accidentally cut into with the backside of tool then you need to have it on. If it is just a simple turned profile, you should be fine.
Regards
Need Help!- Used Machines for the giving!!!!! martyd General Metal Working Machines 5 06-19-2008 09:29 AM
CRAZY LATHE IDEA KENNETH BROWN General Metal Working Machines 13 11-23-2007 05:29 PM
belt numbers for 6" Craftsman Lathe? shootingarts General Metal Working Machines 2 02-08-2006 08:29 PM
Programming lathe with radius numbers mudwhump BobCad-Cam 1 06-07-2004 07:14 AM
I feel like giving up. ynneb General Metal Working Machines 27 05-06-2004 12:19 AM
