Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 05-23-2009, 06:56 AM
jessey is on a distinguished road
BobCad-Cam V21.5 is confusing
Hello Everyone,
This is my first post here and I sure could use a little direction for the BobCad-Cam software.
A friend of mine just purchased the BobCad-Cam V21.5 with training CDs and I'm using an example on CD4 video-62 that shows configuring a simple program to drill holes in a circular pattern and I thought it would be a complete program if I completed all the steps in that video lesson, well I completed the example exercise substituting our own specifications for material size, hole size and selecting a different post processor i.e. the Fanuc 6M which I know will run on a Taig CNC Mill using Mach 3..
When I check the file that's generated in BobCad-Cam for that exercise it's a .cad file but the Mach 3 program is running .TAD files. I haven't gone through all the tutorials yet and was wondering if anyone here could tell me how I get BobCad-Cam to convert the .cad file to a .TAD file so it'll run in the Mach 3 program? I've never operated a cad program before and all the information is somewhat confusing, I sure could use some direction if anyone has the time.
jessey
Old 05-23-2009, 11:57 AM
Kipper's Avatar
Kipper is on a distinguished road
Jessey, When you insert the NC object and create your program click the file/save copy as in the right hand screen...and save it as a .txt file (I believe you had a typo when you said .TAD.....I think you meant .tap?) Stick with it and try not to stress too much...it gets a lot easier generating code....once you've gone bald and grey etc
Keith
Old 05-24-2009, 01:25 AM
works now
Hi Kipper,
Many thanks for your help, it now loads into Mach3 ok, although I have a long way to go, it's beginning to look very promising.
I do have a problem setting the right R value in the G81 Parameters box. If I set it to what it shows in the video to .1 I end up getting an error saying "R less than z in cycle in xy planeLine 7". I tried selecting G73 and other drills and get the same error.
I'm not sure but maybe I need to contact tech support to get a customizable script for use with our taig mill?
Thanks Again
jessey
Old 05-24-2009, 04:43 AM
Kipper's Avatar
Originally Posted by jessey View Post
Hi Kipper,
Thanks Again
jessey
I had the same issue...until I realised I needed to have -23 etc in the Z section....Some cool features are in it (I haven't seen the later versions so have no idea what they are like) I think I'd struggle with any other software now.
Keith
This is all so confusing... Need some help. First CNC, very early on questions. toursbr DIY-CNC Router Table Machines 2 04-22-2009 08:15 PM
WORM GEARS - Challenging but confusing! widgitmaster Mechanical Calculations/Engineering Design 28 09-19-2006 05:19 AM
A Very Confusing Coontroller ? Problem MoonlightMedia DIY-CNC Router Table Machines 28 07-30-2006 07:06 PM
confusing of backlass or backlash saptoro General Metal Working Machines 4 03-08-2005 03:12 AM
