Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 05-21-2009, 11:41 AM
TZ250 is on a distinguished road
Wrapped Ellipse
Guys,
How would I draw an ellipse that is spirally wrapped around a cylinder? The sizes aren't critical now. I'm trying to get the concept, then I'll add the exact sizes later.
BTW, a simple outline of the spiral ellipse will be good enough for now.
Thanks in advance!
Rob in Ohio
Old 05-22-2009, 03:07 AM
BurrMan is on a distinguished road
You could create a helix the size and placement of your cylinder, then create your ellipses and run the sweep command. Watch the lower left corner when your in your command for method tips. Pick an attachment point, then the ellipses then the helix.
Here's a file to help illustrate.
DLG foam or hollow ellipse wings cocodet Parts for Radio Control Models 22 01-18-2011 02:32 AM
Need Help!- super ellipse Solgaard Commercial CNC Wood Routers 2 01-30-2009 01:11 AM
Text Contours (Ellipse) TZ250 Dolphin CADCAM 4 05-10-2008 12:22 AM
Milling an Ellipse Dave4x4 General CAM Discussion 2 02-28-2008 03:24 PM
carve .stl using wrapped axis keebler303 ArtCam Pro 0 02-20-2007 08:31 PM
