Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 05-20-2009, 03:22 PM
TravisR100 is on a distinguished road
New User Questions - CAD
I just recently started using bobcad v23 and I'm trying to get started with some basic drawings. I went through the short tutorials presented without any problem.
It may be that I'm used to Alibre and the functions I'm looking for just don't exist in Bobcad. For instance...
Does bobcad not support constraints? In Alibre if I sketch to lines, one above the other in the xy plane I can simply select the two lines and add a parallel constraint to them. They will suddenly snap to be parallel to each other. I can do the same with angles, etc. in Alibre. Is there no way to do this in bobcad?
Dimensioning in bobcad seems very odd as well. In alibre the dimensions aren't drawing entities. They work almost like constraints. If I draw a line in Alibre and add a dimension to the line for length, it will indeed add a dimension showing the length of that line. If I want to change the length I just double-click the dimension and change it, voila the line will match the the new length I typed in the dimension. With bobcad the dimensions only seem to be for viewing the dimension, not setting it. They also appear to be drawing entities.
Another oddity. If I use the "angle line" function in bobcad to draw a line at an angle to another entity, it asks me for the angle to use when creating the line. It will then draw the line at this angle. Great. But if I want to change the angle after the line is drawn I try right clicking on the line and choosing to "modify entity." Instead of having a box to change the angle I can only change the start and end points of the line in both the x and y axis. How can I simply change the angle of the line without deleting it and drawing it again?
Old 05-20-2009, 03:49 PM
BurrMan is on a distinguished road
In BobCad this is done at design time
Yes
This history mechanism in BobCads Cad side does not perform like this yet.
These functions are not parametric.
Old 05-21-2009, 12:08 AM
With that being said, you can always change the angle of any entity with the rotate or 3d rotate commands. It's just a different way of looking at it.
Old 05-21-2009, 08:57 AM
Thanks for the response. Another question. Let's say I start with a 2d drawing. I define the stock. I create a rectangular pocket. If I now want to fillet the pocket in z (in other words the angle between the xz and yz, not xy) do I have to start over as a 3d solid?
Old 05-21-2009, 09:06 AM
Also, any easy way to draw a hexagon? Octagon? x sided polygon of any sort?
Old 05-21-2009, 09:24 AM
Disregard post #4. It appears I can use the "extrude surface" command to accomplish this.
Old 05-21-2009, 09:26 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
BobCad does not use Parametric Technology. Therefore you can not edit features in a Drawing or Design.
Your better off creating your Design in Alibre then Exporting to your V23 to do the machining.
Or you can get Alibre Cam (which is Visual Mill) and have Parametric CAD and CAM.
The choice is yours to make.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 05-21-2009, 09:43 AM
Thanks Toby. Yep, looks like I'm going to have to create the parts in Alibre then import them into bobcad for machining. The drawing tools on the CAD side in bobcad just seem extremely cumbersome to use. I suppose it's just what one is used to.
Old 05-21-2009, 09:55 AM
tobyaxis's Avatar
Moderator
That is probably your best bet considering you would have to spend more on the Alibre Add-On Module.
Toby D.
Schwarzwald
Need Help!- New User questions TheRo0sTer Haas Mills 5 09-25-2008 01:45 PM
New IH user questions ccmind Industrial Hobbies (Support forum) 10 11-18-2006 12:27 PM
new user questions alchemist Industrial Hobbies (Support forum) 10 11-17-2006 10:17 PM
New user questions John F OneCNC 1 06-27-2003 10:13 AM
