| BobCad-Cam Discuss all BobCad software here. |
SO, I've tested all the Bobcad v23 non-metric post-procs' that I can find, and none have worked 100%. Ex., Bobcad Posts F128456 for Feed20; I've had to manually edit the code in a few ways, but I'd like to know if anyone has a clean Post for the Anilam Crusader M from v23. Thanks! |
| Hythos, Another way this can be done is to make a simple program and post some code, then post it here and talk about what you would like to see different and people can help to massage a post that works for your machine. |
Drill Cycle: ANILAM ELECTRONICS CRUSADER RS-232-C 880915-777 % N0G0G70G90 N10G29T1001X0Z1 N20G29T1002X.25 N30T0 N40Z0 N50X-.3Y1 N60T1 N70G29LV20 10 N80G29LV21 .1 N90G29LV24 .1 N100G81 N110Z-.13 N120X.5Y-.5 N130G91Y-3 N140G90X4.5 N150G91Y3 N160G80 N170T0 N180G90Z0 N190X-3 N200T2 N210G29LV20 8 N220G29LV21 .1 N230G29LV24 .5 N240G81 N250Z-.35 N260X.5Y-.5 N270G91Y-3 N280G90X4.5 N290G91Y3 N300G80 N310T0 N320G90Z0 N330X-3Y1 N340G29E % |
Polar Rotation1 ANILAM ELECTRONICS CRUSADER RS-232-C 880915-777 % N0G0G70G90 N10G52 N20G29T1001X.25Z1 N30T0 N40Z0 N50X0 N60T1 N70G29LV11 2.25 N80G29LV12 1 N90G29LV13 0 N100G29LV15 0 N110G29D7 N120G51 N130X3.3125Y1 N140Z.1 N150F1 N160G1Z-.05 N170G2G91X.875Y0I.4375J0 N180G1Z.1 N190G29LV13 30 N200G29E N210G52 N220T0 N230Z0 N240G0G90X0Y-3 N250G29E % |
| ANILAM ELECTRONICS CRUSADER RS-232-C 880915-777 1 X 0.0000 IN RAPID ABS Y 0.0000 IN RAPID ABS 2 FEED 20.0 IN 3 TOOL 1001 4 X 0.0000 IN RAPID ABS 5 TOOL 1002 6 X 0.1875 IN RAPID ABS 7 TOOL 0 8 G81 9 V11 0.0000 IN 10 V12 -1.5775 IN 11 V13 0.0000 IN 12 V15 0.0000 IN 13 V16 180.0000 IN 14 V17 2.0000 IN 15 V18 2.3600 IN 16 G79 17 X 0.0000 IN RAPID ABS Y 0.0000 IN RAPID ABS 18 ARC CW 19 X 0.0000 IN FEED ABS Y -1.5775 IN FEED ABS 20 X 0.0000 IN FEED ABS Y 0.0000 IN FEED ABS 21 ARC 29 X 0.0000 IN RAPID ABS Y 0.0000 IN RAPID ABS Z 0.0000 IN RAPID ABS 30 X -1.1000 IN RAPID ABS Y -.1000 IN RAPID ABS Z -1.0000 IN RAPID ABS 31 FEED 5.0 IN 32 X -1.0000 IN FEED ABS Y 0.0000 IN FEED ABS Z -1.0000 IN FEED ABS 33 X 0.2500 IN FEED ABS Y 1.2500 IN FEED ABS Z -1.0000 IN FEED ABS 34 X 0.0000 IN RAPID ABS Y 0.0000 IN RAPID ABS Z 0.0000 IN RAPID ABS 43 FEED 20.0 IN 44 DWELL 1.0 45 TOOL 1 46 V20 14.0000 IN 47 V21 0.1000 IN 48 V24 0.1000 IN 49 G81 50 X 0.7500 IN RAPID ABS Y -.5000 IN RAPID ABS Z -.1400 IN RAPID ABS 51 DO 4 52 X 1.0000 IN RAPID INCR 53 END 54 Y -1.0000 IN RAPID INCR 55 DO 4 56 X -1.0000 IN RAPID INCR 57 END 58 Y -1.0000 IN RAPID INCR 59 DO 4 60 X 1.0000 IN RAPID INCR 61 END 62 Y -1.0000 IN RAPID INCR 63 DO 4 64 X 1.0000 IN RAPID INCR 65 END 66 G80 67 TOOL 0 68 Z 0.0000 IN RAPID ABS 4644 X 0.0255 IN FEED INCR Y 0.0000 IN FEED INCR Z 0.0000 IN FEED INCR 5145 X 0.0000 IN FEED INCR Y 0.0000 IN FEED INCR Z 0.0000 IN FEED INCR 5196 X 0.0255 IN FEED INCR Y 0.0000 IN FEED INCR Z 0.0006 IN FEED INCR 5224 X 0.0255 IN FEED INCR Y 0.0000 IN FEED INCR Z 0.0000 IN FEED INCR 980 X 0.0255 IN FEED INCR Y 0.0000 IN FEED INCR Z 0.0000 IN FEED INCR 1481 X 0.0000 IN FEED INCR Y 0.0000 IN FEED INCR Z 0.0000 IN FEED INCR 1532 X 0.0255 IN FEED INCR Y V0 FEED INCR Z 0.0006 IN FEED INCR 1560 X 0.0255 IN FEED INCR Y 0.0000 IN FEED INCR Z 0.0000 IN FEED INCR ---------------------------------------------------------- % N0G0G70G90 N10X0Y0 N20F20 N30G29T1001X0 N40G29T1002X.1875 N50T0 N60G81 N70G29LV11 0 N80G29LV12 -1.5775 N90G29LV13 0 N100G29LV15 0 N110G29LV16 180 N120G29LV17 2 N130G29LV18 2.36 N140G79 N150X0Y0 N160G2X0Y0I0J-1.5775 N170G0X0Y0Z0 N180X-1.1Y-.1Z-1 N190F5 N200G1X-1Y0Z-1 N210X.25Y1.25Z-1 N220G0X0Y0Z0 N230F20 N240G29G4 1 N250T1 N260G29LV20 14 N270G29LV21 .1 N280G29LV24 .1 N290G81 N300X.75Y-.5Z-.14 N310G29D4 N320G91X1 N330G29E N340Y-1 N350G29D4 N360X-1 N370G29E N380Y-1 N390G29D4 N400X1 N410G29E N420Y-1 N430G29D4 N440X1 N450G29E N460G80 N470T0 N480G90Z0 N490G1G91X.0255Y0Z0 N500X0Y0Z0 N510X.0255Y0Z.0006 N520X.0255Y0Z0 N530X.0255Y0Z0 N540X0Y0Z0 N550G29X.0255YV0Z.0006 N560X.0255Y0Z0 % |
| ANILAM ELECTRONICS CRUSADER RS-232-C 880915-777 1 TOOL 1001 2 X 0.5000 IN RAPID ABS Z 1.0000 IN RAPID ABS 3 TOOL 0 4 Z 0.0000 IN RAPID ABS 5 X -2.0000 IN RAPID ABS Y 1.0000 IN RAPID ABS 6 TOOL 1 7 X 1.6520 IN RAPID ABS Y -.3750 IN RAPID ABS 8 Z 0.1000 IN RAPID ABS 9 CALL 1 10 X 2.3775 IN RAPID ABS Y -.3750 IN RAPID ABS 11 AUX 100 12 CALL 1 13 X 2.3750 IN RAPID ABS Y -3.6250 IN RAPID ABS 14 AUX 300 15 CALL 11 16 X 1.6250 IN RAPID ABS Y -3.6250 IN RAPID ABS 17 AUX 200 18 CALL 1 19 TOOL 0 20 Z 0.0000 IN RAPID ABS 21 X -2.0000 IN RAPID ABS Y 1.0000 IN RAPID ABS 22 END 23 SUBR 1 24 FEED 7.5 IN 25 Z -.3000 IN FEED ABS 26 X -1.2500 IN FEED INCR Y -1.2500 IN FEED INCR 27 Z 0.1000 IN FEED ABS 28 AUX 800 29 END --------------- % N0G0G70G90 N10G29T1001X.5Z1 N20T0 N30Z0 N40X-2Y1 N50T1 N60X1.652Y-.375 N70Z.1 N80G29C1 N90X2.3775Y-.375 N100M100 N110G29C1 N120X2.375Y-3.625 N130M300 N140G29C11 N150X1.625Y-3.625 N160M200 N170G29C1 N180T0 N190Z0 N200X-2Y1 N210G29E N220G29S1 N230F7.5 N240G1Z-.3 N250G91X-1.25Y-1.25 N260G90Z.1 N270M800 N280G29E % |
| Here are a couple entries I'm trying to resolve: ---- 110. Tool list format. "(MTOOL","T100",list_tool_number,"S1","D",tool_diameter,"H",tool_length,"DIAM_OFFSET ",list_tool_number,"= ",tool_radius,")" --- Correct input format to define a standard tool should be: N T1001 X.25 Z1.5 SO, I would suspect the Post should include: "T100",list_tool_number,"x",tool_radius,"z",tool_length Furthermore, I would expect I won't need to define G44 as the tool-length is included in the tool-definition... |
| Next, Subroutines have a redundant call... IE: ----- 7. Sub program call n,sub_call,sub_num,comment_start,"SUBPROGRAM CALL",comment_end 8. Sub definition sub_num_with_prefix,sub_comment 9. Sub program return rigid_tapping_end n,sub_return,comment_start,"SUBPROGRAM RETURN",comment_end ----- results in: N005 G29 C C10 $ SUBPROGRAM CALL N010 G29 S C10 $SUBPROGRAM OF S100 Correct formatting should be: N005 G29 C1 (G29 is required for 'special' inputs) So here's what I I've modified it to: 7. Sub program call n,"G29","C",sub_num,<comments, blah blah blah, ect> 8. Sub definition N,"G29","S",sub_num,sub_comment ** However - the program #'s are still 2-digit instead of 1. Previous tests failed at 2-digit subroutine numbers, but they might work now. I'd like to use a single-digit sub# |
#10
| did you ever get your post going the posts on there web page are non functional for the crusader M Defining a tool in the post T1001 X.25 Z1.5 T10 tells the controller you are inputing 01 the tool number, X the tool dia Z the tool offset at a glance the tool call must be T01F7.5 T for tool , 01 for the tool number and yes the 0 must be there F for feed rate and should be called with the tool Cheers |
| Need post for Anilam Crusader Series M to Bobcad version 17 | whiz | BobCad-Cam | 3 | 02-09-2008 05:46 PM |
| Need post for Anilam Crusader Series M to Bobcad version 17 | whiz | Post Processor Files | 0 | 11-28-2007 07:38 PM |
| Mastercam V9.1 - Anilam Crusader G Post | zoeper | Post Processor Files | 0 | 08-16-2007 02:07 AM |
| Anilam:Crusader M Post for MC9? | ZachB | Mastercam | 0 | 06-18-2006 05:00 PM |
| BobCad with Anilam Crusader II | racerguy13 | BobCad-Cam | 1 | 01-28-2006 09:16 PM |
