Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 04-08-2009, 11:31 AM
capital is on a distinguished road
Bobcad V23 predator
We installed Bobcad V23 and the Predator CNC Editor for Bobcad (version 2005.7.0.40) and we are unable to drip feed. We had an older version of predator that we used constantly to drip feed but, when we installed the predator that came with bobcad we had to remove the older version that we no longer have the license for. I can't seem to get a straight answer from Bobcad they want to try to find something wrong with my machine, pc, or process however, so far they cannot tell me why I can't drip feed. Does this version of predator have the capability to drip feed. I have tried different DNC property configs, I know the baud rate and all of that is correct for the machine. Predator charges for tech support and bobcad tech support won't respond with a solution.
Old 04-08-2009, 12:50 PM
1234567 is on a distinguished road
Does the machine recive any code?
Old 04-09-2009, 08:24 AM
The One is on a distinguished road
capital,
Yes, the version of the Editor that ships with BobCAD V23 can drip feed, that is send the program in small increments to the machine.
Are you getting an alarm at the machine?
Regards
Old 04-09-2009, 11:28 AM
the only way to get it to drip feed is to unclick "wait for cnc" and then set a send line delay. That is not a drip feed. I cannot get predator to communicate with the machine and send the data as the cnc requires it. Using a line delay depending on the feed rate and length of cut the machine is starving (sitting still) or data starts to overflow.
Old 04-09-2009, 02:31 PM
Your cables haven't changed, right? Only the software you are using for communication.
Have you tried using the Both option for Flow control, with your Wait for CNC option selected?
Also, which version of Predator were you using before? There is something here that will expose the solution, it's just a matter of what.
Regards
Old 04-12-2009, 01:56 PM
laserkey is on a distinguished road
have you set your program to work as windows xp or are you using xp already.
Old 04-14-2009, 01:20 PM
yes we already are using Xp.
Old 04-17-2009, 07:01 PM
gm3211 is on a distinguished road
What is the CNC Control we are working with? Sometimes you may need to use the line send delay or character delay to get the machine to communicate in drip feed mode.
The Predator CNC Editor will DNC (drip feed) with no issues for years. Most of the time it is settings in the software or something like the comm port used mis-configured.
Need help, call us, we support Predator and can help.
Greg Mercurio -Shop Floor Automations
www.shopfloorautomations.com /619-461-4000
Newbie- Predator for BCC Basic VS Pro cncpilot BobCad-Cam 1 03-27-2009 12:02 PM
Need Help!- Predator headers Richprop3 BobCad-Cam 3 03-18-2009 09:57 AM
NEED HELP - AccuMill AM1547 + BobCAD + Predator AccuMillGuy General Metal Working Machines 0 03-13-2009 02:25 PM
Predator DNC lyncomputer Computers and Networking 2 09-20-2007 08:13 PM
predator dnc dcr726 Mazak, Mitsubishi, Mazatrol 3 01-15-2005 11:01 PM
