Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 04-01-2009, 07:32 PM
cheubach is on a distinguished road
Dimension setting not holding?
V22.073 pro (1137)
I have impute and saved all of the settings in the dimension tab of the settings default and when I create a new drawing I can select the dimension tool and all the fields are populated with the correct data. But when and if I ever close the file and reopen it to make any changes or even if I just try the dimension tools the data fields are blank when it opens. I have seen where other have posted similar problems and I know how to work around the issue by going back to Preferences > Settings Part > Dimensions then simply select any of the data fields I don’t even have to make any changes. I can then close the out of the setting menu reselect the dimension function button on the menu bar and the data fields will be populated
My question is can anyone tell me what I am doing wrong? Is there any way make these settings stick and avoid all of these unnecessary steps?
Old 04-04-2009, 05:30 PM
chaz6966 is on a distinguished road
same problems here
i have the same problems in v22, i also have the same problem in version 23.
which there was an update in 23 to fix the problem but my prefferences for part keeps changing to 3plc. decimals and scale of 25.4 to 1. and the update is on the new disks that i got.
Looking for Gerber Dimension 200 gio666 CNCzone Club House 0 06-01-2008 10:32 AM
Looking to buy a gerber dimension 200 gio666 Canadian Club House 0 05-27-2008 03:39 PM
SL-30 dimension needed rka Haas Lathes 7 03-31-2008 10:24 PM
Need Help!- Changes to Dimension Preference SPEEDRE Solidworks 2 02-01-2008 01:03 PM
Gerber Dimension 200 teemac Commercial CNC Wood Routers 1 04-22-2007 12:30 AM
