Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 03-20-2009, 10:26 AM
PinMan's Avatar
PinMan is on a distinguished road
2D Dimensioning in 3D?
Ok, so I am going to try to explain this the best way that I know how. I hope that you guys can follow me.
A lot of the time, I have to import 3D drawings from other software, usually Inventor and Solidworks. From these drawings, I have to build a fixture for holding. I have the hardest time dimensioning these 3D drawings in bobcad because the dimension feature wants to tell me the distances in real 3D space. But, what I really need, is the 2D dimension for the current view that I am looking at.
As is many times the case, I may need to get the X and Y coordinates of a feature, but not neccessarily the Z at the moment. But when I try to dimension, it gives me a point to point distance in X, Y, and Z.
If I havent explained this well enough, let me know and I will try better.
Hope you guys can help me out.
Thanks in advance
Old 03-20-2009, 02:15 PM
Allen123's Avatar
Allen123 is on a distinguished road
Few things you can do.
Change your UCS so it's in the plane you need the dimension for This way the Z value won't get in the way.
The other thing you can do is extract the wire frame and project it onto a surface in the X Y. This way you'll get ride of all the z values.
If you are running a the v23 you now can dimension a point so that can be very useful as well.
Old 03-20-2009, 02:23 PM
BurrMan is on a distinguished road
Hi Allen,
Doesnt X-Ordinate or Y-Ordinate do this also? Or does it still give a 3d readout?
Old 03-20-2009, 02:27 PM
PinMan's Avatar
Ahh, thank you so much
I knew it was something easy that I was overlooking
Old 03-20-2009, 02:29 PM
PinMan's Avatar
those both give 3d readouts
Old 03-20-2009, 02:32 PM
Allen123's Avatar
That just has to do with the way the numbers come out on the dimension if they go along the X axis or the Y axis. Nothing to do with the Z values.
BobCAD is really only designed to dimension in a 2D plane.
Pin Man, Do you want to post your file?
Old 03-20-2009, 03:41 PM
chaz6966 is on a distinguished road
projecting wire frame to x-y
how do you project a 3d wire frame onto a x-y surface...
you can trim a line to screen wich the z depth does not matter.
wouldnt it be easyto dimension screen so anything picked would be flat, no z depth.
it is very iritating trying to get something dimensioned especially if there z's are not much different . then you dont realize your .002 off until later when you realize something is amuck.
Old 03-20-2009, 04:09 PM
Allen123's Avatar
Exclamation
You use project on surface, it's found under the other menu.
I agree you should be able to dimenstion to screen and that way it' all in the XY plane. This is something that would be useful, but you can always mesaure your part regarless of them being 3D or not.
Use the verify feature the only thing is it doesn't print out those values.
Old 04-22-2009, 08:06 PM
rockcraft is on a distinguished road
I bought Omax Machiningjet 55100.
I have to make different designs in the marble and granite(Madalions). Do you any body who assist me to getting cad/cam file of different designs. see attachment.
BobyClick image for larger version
Name:	Beige carpet.jpg
Old 04-23-2009, 10:58 AM
Allen123's Avatar
You know the carve wright machine would be perfect for what you are doing.
http://www.carvewright.com/
It comes with it's own software and it cheep!
This machine is for wood
  #11   Ban this user!
Old 04-28-2009, 01:01 PM
PinMan's Avatar
I ended up doing it the long way around, but basically I was trying to put some simple 2D dimension on this 3D model of some test equiptment that I designed. Here is the file.
Need Help!- Dimensioning A Solid TZ250 BobCad-Cam 1 02-13-2008 08:12 AM
Dimensioning and help files? LorenzoNH TurboCAD/CAM 3 04-27-2007 03:33 PM
dimensioning solids sc_crasher BobCad-Cam 1 03-16-2006 01:56 PM
Auto dimensioning? trubleshtr Autodesk Software (Autocad, Inventor etc) 1 03-24-2005 06:05 PM
Dimensioning? Ken_Shea OneCNC 4 07-09-2003 09:51 AM
