Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 03-17-2009, 06:35 PM
chaz6966 is on a distinguished road
milling a straight line that follows a 3d path
does anyone know the easiest way to mill a runner with a ball cutter and follow a centerline that runs down a 15 degree wall to a depth of 1.225 from zero at p/l.
engraving does not go down z depth
and i need several paths to remove the stock.
Old 03-17-2009, 07:00 PM
BurrMan is on a distinguished road
What Version do you have?
The V23 has a 3d engrave that will follow a 3d path but it doesnt clear stock. To clear stock away you would have to create some other geometry to run another operation on. Is that what you are asking?
Old 03-17-2009, 09:40 PM
mmc005 is on a distinguished road
Can you extract your edges from the solid, then use a 2-d profile with spring passes for the stock removal?
Can you post your file or a print of the part?
Dave
Old 03-18-2009, 12:16 AM
ya sort of.
i dont know why they didnt offer pick depths in the engraving.
if your going to do letters .015 deep and use a .016 ball mill you need to pick it several passes.
Old 03-18-2009, 12:18 AM
also i just drew a wire path so i wouldnt have to create surfaces of a trapazoid runner going down a 15degree wall, following it.
Old 03-18-2009, 09:40 AM
Allen123's Avatar
Allen123 is on a distinguished road
This is a good point. If you wanted to profile a 3d chain, there is no easy way to rough it out.
BobCAD 07 / 23 will let to select and machine the 3D path at a single depth but there is not option to rough it out.
In the older version of BobCAD you had a 3D rough on any chain, so it would be quite easy to do in V21 or earlier.
Something BobCAD should add to the software is a roughing option for the 3D engraving feature.
Really it should be more that an engraving feature is should be a 3D profile feature with roughing options. Anyone agree?
Solid with a 3D profile
3D Engrave tool path
V21 3D profile 3D rough
I am not sure if I understand the "runner" correctly, and but do these screen shots come close to what you are talking about?
Old 03-18-2009, 10:04 PM
i dont see any screen shots.
i had to use the 3d evgrave for a tool path and edit my offset at the machine to drop .125 deep in .005 incriments.
which is a major pain in the butt. cant program anything else have to sit and watch the machine to keep it going.
Old 03-19-2009, 05:50 PM
Matt Sachs is on a distinguished road
V22?
Have you tried a slice planar? Set your boundaries closer than the step over. This will allow you to pick the depth of cut for each pass.
Old 03-20-2009, 09:12 AM
Allen123's Avatar
Yeah I don't know if a planner tool path is going to work. Really all he is doing is a 3D profile. The planner would want to step over not to mention it wouldn't follow the shape he would be cutting. Like a u shaped profile.
Old 03-20-2009, 11:28 AM
You are right. I tried it and couldnt make it work with a planer cut
Offset Chain Milling vs Path Milling ynnek TurboCAD/CAM 1 03-11-2009 06:29 PM
Water-Line Tool Path with BCC Kiwi BobCad-Cam 5 06-12-2007 06:36 AM
Ok, I need some straight answers about DIY milling machine! CNCadmin DIY-CNC Router Table Machines 0 11-27-2006 11:00 AM
Ok, I need some straight answers about DIY milling machine! chola DIY-CNC Router Table Machines 8 11-27-2006 10:10 AM
Aluminum extrusion as a straight-line ball slide Charlye Linear and Rotary Motion 6 04-21-2006 10:41 AM
