Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 01-02-2005, 01:34 PM
pauls is on a distinguished road
DXF file crashes program
I've been trying to import this file both as iges and dfx but BobCad won't run it and the program crashes version 19.6. I can't pocket or pick drill sequences. Any help?
Old 01-02-2005, 02:59 PM
HuFlungDung's Avatar
Moderator
It's likely a garbage file. It has barely anything in it. What program are you using to create the file from?
Old 01-02-2005, 07:13 PM
Bubba's Avatar
Bubba is on a distinguished road
I opened it, and there was nothing there.
Bubba
Old 01-02-2005, 09:18 PM
Sorry, I don't know why it didn't load, I'll try again.
Old 01-03-2005, 07:34 AM
Bubba's Avatar
Paul,
Loaded just fine and didn't crash in acad or in my cam (SheetCam), but it sure is made up of very tiny segments. Even the holes are done that way. I have played with it a little to use circles for the holes, and then made a couple of circles connected with lines at the quadrants and trimmed them out for the port holes and tried opening that and it works fine! I think the problem is that you have to small of segments for the program to be able to read it.
Bubba
PS: I also just noticed this might be something that was traced and there are several "jagged" lines on the exterior profile. I have to go to work now, but if you would like, I will clean the drawing up as I understand it and send it back if you would like? (obviously, I would check it out in my cam first
Old 01-03-2005, 09:36 AM
Support Member
CNCdude is on a distinguished road
Your file
I downloaded the dxf file and opened it in V19.8 without problem. I take it that this file was originally a solid. With some simple editing I was then able to create profile and pocket toolpath for the part after verifying the X, Y and Z extents. If you have the IGES model, just open that and create toolpath. However, either way BobCAD did not have a problem with it. We did include some enhancements to the software since V19.6. Update your software.
CNC Dude
Old 01-03-2005, 04:53 PM
Bubba's Avatar
Paul,
Well, I did as stated and found several open points etc. I have overlayed the major points and then ran it through my cam. It works. I have placed the salient shapes on seperate layers and left your original layer for comparison.
Bubba
Old 01-03-2005, 07:24 PM
Guys, Thanks so much for the help. I've been through all the tutorial CDs but still need help. I appreciate it.
Paul
G-Code to DXF WayneHill OpenSource Software 200 04-22-2012 09:51 PM
anyone know of a freeware program to turn text to dxf? ljoe1969 Autodesk Software (Autocad, Inventor etc) 7 01-18-2012 08:52 AM
Emco Compact 5 PC...have ???? Double G Mini Lathe 42 08-22-2010 06:26 PM
parametric programming Karl_T CamSoft Products 21 05-24-2005 02:58 PM
A few honest questions HuFlungDung CamSoft Products 8 06-15-2004 06:24 PM
