Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 03-15-2009, 05:13 PM
chaz6966 is on a distinguished road
toolpath lines
is there anyway to get rid of the toolpath lines after you compute a toolpath.
without deleting function that you have chosen... this is very irritating to delete the function and retype in all the information allover again just to do another pathand see what your selecting for geometry..
Old 03-15-2009, 05:23 PM
BurrMan is on a distinguished road
If you click the plus sign on that feature you will see it say "Rough" and "Finish". If you right click either of those and choose "Blank", they will be hidden. You can also change the color of each individual pass.
Burr
Old 03-15-2009, 09:18 PM
ok i will try that.
when i open cam tree the, the cam part tree is minimized and the turning stock and edm stock are expanded.
is there any way to keep the cam part expanded and keep the turning stock and edm stock minimized.
or even get rid of the lathe and edm stocks off the tree for now. i dont have a need for them.
Old 03-15-2009, 09:24 PM
ok tryed the blank, and it gets rid of the color ok so i can see my detail,
but when i edit my toolpath and re run it now there is no color and i cant see the new path.
Old 03-15-2009, 09:29 PM
Unblank it. Repeat step 1.
Old 03-15-2009, 09:31 PM
Originally Posted by chaz6966 View Post
ok i will try that.
I dont think this is in it yet. I have seen it mentioned before though.
BTW: Mine opens up as all three collapsed. Make sure you are on the latest build of 1276.
Go to Help menu-About BobCad and see if it says Build 1276. If not then:
http://www.bobcad.com/updates
run this as an updtae to the existing install. It is not a full install. It's an update.
NOT break arc into lines cncuser1 Mastercam 8 05-07-2008 09:48 PM
CAD HELP: 4 lines to 1 box/object how to? FireFghtr General CAM Discussion 7 02-24-2006 04:03 PM
Can't see lines Mr.Chips TurboCAD/CAM 4 04-03-2005 11:29 AM
Need help extra lines in dxf carlnpa Mach Software (ArtSoft software) 3 03-19-2005 04:48 PM
Lines and Joining them scottsss Rhino 3D 5 07-29-2003 06:41 AM
