Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 03-12-2009, 03:40 PM
Fadal Error is on a distinguished road
V23- What is "Shell2d error 4: overflow" ?
I am trying to generate a Z-level rough pass on a small mold and I keep getting this error. Z-level rough works on the mating part in a different drawing.
V23 build 1126
Old 03-12-2009, 04:20 PM
The One is on a distinguished road
You probably have overlapping surfaces or solids in the part. I have seen this error before, but it is commonly because two surfaces or sets of surfaces exist in the same space.
Regards
Old 03-12-2009, 04:51 PM
Hmmm...OK. I get a good tool path with slice planar. I get a weird step in the middle of an angled plane when I try equidistant offset.
Old 03-13-2009, 09:11 AM
Is it possible to post the file? Like I said, I have seen this before, but it is a matter of seeing the part to identify the surface(s) causing this.
Regards
Old 03-13-2009, 11:17 AM
moldmker is on a distinguished road
Sometimes turning the shading off (press "s" in cad window) will show funky untrimmed surfaces that overlap.
moldmker
"Runtime error 9 - subscript out of range" on Techno CNC interface zhoudfoster General CNC (Mill and Lathe) Control Software (NC) 4 10-25-2009 11:57 PM
Need Help!- Interesting "Gross Position ERROR A" with no limit detection A.A Bridgeport and Hardinge Mills 1 01-14-2009 03:45 PM
BOSS8 "+Z OVERFLOW" error message jonny Bridgeport and Hardinge Mills 11 05-29-2008 05:12 AM
V2XT error message "DRIVE FAULT detected (0,z,y,x) check log" rfdoyle Bridgeport and Hardinge Mills 4 10-08-2007 04:35 PM
Error adding fillet "Couldnt add entity" carbidecraters BobCad-Cam 29 09-27-2007 02:21 PM
