Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 03-12-2009, 09:54 AM
ssoptical is on a distinguished road
Red face How to edit posts
need to know what to change in my postprocessor to stop getting feed rates
in every line of code.
thank's David.
Old 03-12-2009, 02:24 PM
BurrMan is on a distinguished road
Did the Modal setting not work for you?
Old 03-12-2009, 02:40 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
thank's David.
You might want to mention what machine control and post your using??
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 03-12-2009, 04:28 PM
The One is on a distinguished road
Open your post in Notepad.
Then look for line 535. Change the letter at the end of this line to a 'y' and save the file. This should take care of it.
Regards
Old 03-12-2009, 07:17 PM
Thumbs up thanks for your help
Regards
burrman & the one,
i didn' really quite under stand the modal concept & the one, i was trying different post changes & found the the line 535 and changed it to y.
Thank both of you for your replies it will save me a lot of time editing my programs.
Yhanks again David.
Old 03-12-2009, 09:30 PM
SSOptical,
The modal thing would be sort of like saying, "If you've already told me, Dont tell me again unless the data has changed!"
So like tool changing set to modal y, means if the first operation has a .25 endmill and the second operation uses a .25 endmill, there would be no need to print the tool information again in the code. If it was set to N, then .25 would print out in both features.
Setting the feeds to Y would mean only print out the feeds when they "Change", having it set to N would mean "Always" print out the feeds.
Anyway
Old 03-13-2009, 06:50 AM
BurMan, Thank's For The Modal Lesson.
SSOPTICAL.
edit posts manual manuelc149 Mastercam 7 10-02-2007 11:14 PM
Admin, I can no longer edit my posts? Guldberg Forum Questions or Problems 6 07-19-2007 02:56 AM
BobCAD posts vs. Mastercam posts justCNCit BobCad-Cam 124 08-16-2006 03:17 PM
