Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 03-11-2009, 03:30 PM
p&ccnc is on a distinguished road
No data to verify
Why would I be able to generate a tool path, and then not be able to verify the tool path?
Old 03-11-2009, 04:24 PM
Allen123's Avatar
Allen123 is on a distinguished road
That's a good question.
What version are you running?
What I would do in un install predator software.
Then re install from the system sub folder in the V22 or V23
That should fix the problem
Old 03-12-2009, 07:53 AM
We are using V23. I have a suspicion that the software didnt load completely because I Had loaded onto a laptop then had to move to PC because of graphics card issues. I will try uninstalling and reinstalling. Thanks,
Old 03-12-2009, 08:55 AM
The One is on a distinguished road
Uninstalling and reinstalling isn't necessary.
The reason that there is no data to verify is because the directory that BobCAD is saving the data to, is inacessible to Predator. You just need to tell BobCAD where to put the files.
Click on Preferences => Settings Default.
Then click on the Directories option, on the left.
You will see an option for Project Directory, click on the button to the right of the field. You will then need to direct this option to "\\Program Files\Predator Software\Common Files\Jobs".
Once this is done, click OK and you should be able to verify just fine. If this doesn't work, then you can try the reinstall, but I doubt you will have to.
Regards
Problem- VERIFY ??? nelZ BobCad-Cam 1 12-22-2008 08:28 AM
Backplot/Verify dpark1 Mastercam 4 10-09-2008 07:13 PM
Using STL Files For Verify Mastercam User Mastercam 27 05-09-2008 09:23 PM
Need Help!- VERIFY LYN BYRD BobCad-Cam 6 02-12-2008 01:48 PM
Please verify my code Hack General CAM Discussion 6 11-05-2007 07:41 PM
