| BobCad-Cam Discuss all BobCad software here. |
| Tool Path Generation Issue I am just running through some of the tutorials in the manual and have hit this problem in more than one. I try to generate a tool path on this basic facing operation and it comes out all screwed up, any ideas? I attached a word doc of the problem. The path should be completely vertical but it is slanted, not sure why. Forgot to mention that I am running V21. |
| This could be caused by a couple of things. Make sure that you choose the vertical line first when your picking your geometry for facing. Also, check to make sure that the direction of the lines go from front to back and from center to od. Upload your file so we have a better idea of why this is happening. |
| First off you are turning a part. It might be a good idea just to use your canned cycle from your machine instead of having BobCAD generate the tool path. Depending on your post these canned cycles may be built in. I used the Fanuc 18I Draw the profile you want to face Select the profile and then go to the NC cam and choose the face canned cycle. ![]() A window will pop up asking questions about the cycle fill in the blanks click ok ![]() and then code will come up. N10 G72 W.05 R.1 N20 G72 P30 QU.015 W.02 F3 N30 G0 X-0.0026 0113 N40 G1 X-1.2682 F20. N50 Y5.605 N60 G70 P30 Q Depending on what post you are using these steps will be different. *** You can see I have something wrong because the Q is not calling what line of code to go to.... ![]() I think the issue with your file is you didn't have the boundary setup right. Try it again using a boundary like this. ![]() This is what your tool path should look like. And you code will look like this: N10 G0 X-0.0031 Z0.0472 N20 G1 Z-0.0028 F20. N30 G2 X0.0111 Z-0.0205 I-0.0017 K-0.0159 N40 G1 Z-0.1028 N50 X5.5875 N60 Z-0.0028 N70 X5.5375 N80 G0 X0.1111 N90 G1 X0.0111 Z-0.1028 N100 Z-0.2028 N110 X5.5875 N120 Z-0.1028 N130 X5.5375 N140 G0 X0.1111 N150 G1 X0.0111 Z-0.2029 N160 Z-0.3029 N170 X5.5875 N180 Z-0.2029 N190 X5.5375 N200 G0 X0.1111 N210 G1 X0.0111 Z-0.3029 N220 Z-0.4029 N230 X5.5875 N240 Z-0.3029 N250 X5.5375 N260 G0 X0.1111 N270 G1 X0.0111 Z-0.403 N280 Z-0.503 N290 X5.5875 N300 Z-0.403 N310 X5.5375 N320 G0 X0.1111 N330 G1 X0.0111 Z-0.503 N340 Z-0.603 N350 X5.5875 N360 Z-0.503 N370 X5.5375 N380 G0 X0.1111 N390 G1 X0.0111 Z-0.6031 N400 Z-0.7031 N410 X5.5875 N420 Z-0.6031 N430 X5.5375 N440 G0 X0.1111 N450 G1 X0.0111 Z-0.7031 N460 Z-0.8031 N470 X5.5875 N480 Z-0.7031 N490 X5.5375 N500 G0 X0.1111 N510 G1 X0.0111 Z-0.8032 N520 Z-0.9032 N530 X5.5875 N540 Z-0.8032 N550 X5.5375 N560 G0 X0.1111 N570 G1 X0.0111 Z-0.9032 N580 Z-1.0032 N590 X5.5875 N600 Z-0.9032 N610 X5.5375 N620 G0 X0.1111 N630 G1 X0.0111 Z-1.0033 N640 Z-1.1032 N650 X5.5875 N660 Z-1.0033 N670 X5.5375 N680 G0 X0.1111 N690 G1 X0.0111 Z-1.1033 N700 Z-1.2033 N710 X5.5875 N720 Z-1.1033 N730 X5.5375 N740 G0 X0.1111 N750 G1 X0.0111 Z-1.2034 N760 Z-1.2683 N770 X5.5875 N780 Z-1.2034 N790 X2.7993 N800 G0 Z0.0472 So you can see running the canned cycle is better. Why? Smaller code and if you want to make an adjustment you can just edit the canned cycle. ![]() Sample tool file Last edited by Allen123; 03-11-2009 at 01:17 PM. Reason: image insert |
| Allen... You're one smart cookie. All your tool geometries in one file so you don't need to go looking for them in the directory. Thanks, moldmker |
| Need Help!- 3d tool path generation BCC V21 | Sam A | BobCad-Cam | 7 | 02-08-2009 12:20 PM |
| Need Help!- can't get the tool path right | msn_jrd | Mastercam | 3 | 07-21-2008 11:43 AM |
| 3-D TOOL PATH | reedmiles | BobCad-Cam | 15 | 02-02-2008 08:08 PM |
| Tool approach Tool Path | Kiwi | BobCad-Cam | 28 | 07-05-2007 03:35 AM |
| tool path generation BobCAD V18/19 | inthedark | BobCad-Cam | 3 | 02-10-2004 10:14 PM |
