Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 03-05-2009, 04:02 PM
project5k's Avatar
project5k is on a distinguished road
trying to get a good 3d finish
I've read all over here and i'm still not understanding how to do what i want to do...
First, some basics, V22 pro with art.
just as an example, lets say i have a hemisphere depression into a flat topped block,
now i can do the basics of getting that machined, but my questions start when i want to try and get a better finish to my parts through machining it, rather than hand sanding and polishing... as it is now, all i have is endmills, so i'm working on getting some ball mills,
but what function in the software should i use to get that nice smooth finish like i see on every tv show, so that really all i have to do is a little polishing?
when i bought the software i was told somethng about equidistant somethine or another.... but i dont understand how to use it or if that will even give me the results that i want...
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
Old 03-05-2009, 04:24 PM
Allen123's Avatar
Allen123 is on a distinguished road
Exclamation
Yes run a ball mill!
When you step the tool over there are ridges left. By reducing the size of the ridges you get a smoother finish.
You do this by changing the step over for the tool.
The smaller the step over the small the ridges.
The better finish you want the smaller the tool step over will be.
Old 03-05-2009, 04:41 PM
project5k's Avatar
ahh ok, i kinda thought that, but wasnt sure, so lots and lots of small passes then.. cool, now what about the equidistant stuff in bobcad? what would i use that for?
Old 03-05-2009, 05:04 PM
Allen123's Avatar
Exclamation
Same thing, but the equi D. tool path does an absolute step over to the surface where the slice tool paths are incremental.
This about it this way when you are cutting a slanted surfaces using a planner tool path.
You give it a step over amount, what ever it is, the software steps over that amount but the slanted surface will have different ridges or scallops.
If you use the equi D. because it's an abs step over you will get the same scallops over the slanted surface.
See how the planner tool path had the different ridges or scallops and the equi D below has the same ridges or scallops through out.
Keep in mind that it's just not about the step over it's also about tools and speeds and feeds.
Old 03-06-2009, 09:15 AM
project5k's Avatar
ahh, ok, i see now, that would make a difference in the quality of the finish of my parts...
ok, so i just ordered a couple ball mills in the sizes i'm most likely to use... I just went ahead and got them from enco, i've allways had good luck with them, we'll see how this turns out.. i got:
321-6605
321-6610
321-6615
and a couple other regular endmills that i needed...
Need Help!- Can't get a good surface finish! welchland General Metalwork Discussion 5 09-25-2008 11:16 PM
Help getting a good finish on a circular boss maxine Mastercam 7 06-18-2008 05:07 PM
How good of a finish do you get on the TM series mills.. l u k e Haas Mills 24 02-25-2008 06:10 AM
Getting a good finish turning copper Warpspeed General Metalwork Discussion 5 07-21-2007 04:57 PM
Good plastic Finish Smackre Glass, Plastic and Stone 1 06-06-2006 02:46 AM
