| BobCad-Cam Discuss all BobCad software here. |
| Iam carving flowers with v-cutter. I draw a simple 3d close spline for the tool path . Now my problem is to clean the inside of the petal, I cant seem to make a surface of a close 3d spline . witch way should I go? I have done it with offsets but it does not clean smooth enough. Its the flower at top right on attachment. |
| Why would you go through all that work. If you run the BobART in V23 you can do this automatically? I spent about 5 mins tracing over your drawing with the spline feature in BobCAD. Then I used the pull and tug feature to smooth our the same and get thing close. This was your drawing: ![]() In blue is the spline I created with BobCAD. ![]() When you get the BobART software with BobCAD you also get the V carve tool path. This will let you carve with a v tip cutter in 3D based on a 2D profile. It also has a cool clean up feature that lets you "rough" the shape out with an endmill first and then come back with the V tip for the walls. The picture below is the tool path. 2 colors because there are 2 tools being use. ![]() ![]() This one I just used 1 tool , the V tip cutter |
| Sorry I posted the wrong drawing . Forgot to say that I am still with version 21, So I have to draw my own toolpath by hand for v-cutter.Now if you look at the flower on the top right of the drawing (hope it is the right one this time)its this type of petal I want but i need to clean the middle of it . Now that I think of it , it might be a geometric impossibility to create a surface with a single 3d close spline? |
| New X2, what now? How do I clean it. | chola | Benchtop Machines | 3 | 10-01-2008 06:25 AM |
| Help Me clean up this DXF File | Mr.Chips | Mach Software (ArtSoft software) | 10 | 12-12-2007 02:31 PM |
| help getting a clean weld bead | Rich05 | Welding, Brazing, Soldering, Sealing | 4 | 11-18-2007 07:22 AM |
| How Clean do you keep your machine? | ozzie34231 | Polls | 5 | 10-30-2006 08:15 AM |
