Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: importing files into v23 bobcad from alibre
    May 2005
    Hi what are the best files to import into bobcad from alibre to keep it stable
    it seems everytime i try to import a stl file it crashes after about 1 min" and the stl are white blank looking but i know its there." and stp arent very good either which one do you guys recommend
    ALSO anyone know what happened to the bobcad support forumn
    " im running vista with an nvidia card i have done the bobcad optimizie"
    JOhn
    Company Representative Allen123's Avatar
    Apr 2007
    Thumbs up
    BobCAD will work with STL files but I don't think you want to use them for mechanical parts.
    STL files are best for art type work. The main reason is you can't edit the file, get wire frame from it or any other editing.
    You can cut an STL and your can scale it up or down. But that is about it.
    As far as file translators go with BobCAD:
    DXF wire frame
    IGES trimmed surface files
    Step Solid files
    BobCAD has other translators but this breaks down what works the best for importing into BobCAD
    BobCAD does have direct file translators for autocad and solidworks and rhino, SAT, and X_T and B
    But most of the time I use a STEP for solids and that seems to work the best.
    Yes you can still have an issue with import because of bad surfaces poor drawings or un support surface types.
    Sometime you need to clean up the file from import, or edit for machining.
    Either way I feel BobCAD does a good job of this!
    May 2005
    it is definitly the nvidia card i did all the settings per bobcad but still does it
    crashes about every30 seconds when i take the card out bobcad doesnt crash. all of my other programs work fine with the nvidia 8600gt except bobcad maybe somebody will jump on here and give me some help if i take the card out man alibre rhino corel they all look horrible i have to keep this card
    John
    Apr 2007
    I think BobCAD has an issue with the 8 or 9 nvidia cards. I believe they are working on a fix.
    You're running vista?
    Mar 2004
    Sunnyvale
    I have 8 series card and vista no problems. update your driver if you havent and if you havent there is a fix for vista on the support page.
    Hope something helps. good luck
    Randy
    Banned
    Mar 2008
    Quote Originally Posted by Allen123 View Post
    It not just Bobcad that has an issue with nvidia cards
    http://news.cnet.com/8301-17938_105-10000353-1.html
    "The issue is a weak die/packaging material set, which may fail with GPU temperature fluctuations. If your GPU fails, you may see intermittent symptoms," the Dell blog said.
    Mar 2004
    Sunnyvale
    well
    now I know why it drops out in gaming apps.
    looks like its time for another card but no issues with bobcad as of yet.
    Randy
    Registered BurrMan's Avatar
    Dec 2008
    Quote Originally Posted by dgalaxy View Post
    JOhn
    I'll tackle the hard ones!
    http://www.bobcadsupport.com/forum/ is the support forum for the software.
    for your imported models, enter selection mode and select the model then right click and choose ok. Then right click the model again and choose Modify Attributes-Color and pick the color you want it to be.
    If you rotate the view a bit those white invisible models kindof appear a bit more.
    Moderator tobyaxis's Avatar
    Jan 2006
    JOhn
    Export a STEP AP 203 file (*.stp)
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jan 2006
    John
    You may have to adjust the Nvidia Settings. For example the Triple Buffering works best turned OFF, while the Thread Optimization is set to AUTO, Maximum Pre-Rendered Frames set to 8, etc.
    This is why I stepped away from common graphics cards and went to the CAD/CAM cards. There are fewer problems and better results.
    One question, does your 8600gt have shared ram memory? You should really be using a card with Dedicated RAM.
    If your card is using shared memory try increasing the virtual memory or buying more ram sticks. This might help with small files around 25mb but larger files around 35-100 will have white out screens and eventual crashes.
    Good luck.
    Toby D.
    Schwarzwald
    Aug 2003
    This is always a fun debate...which came first the gamer or the drafter.
    I like to think that the gamer came first, but then again how would he play a game without somebody creating the characters. But how would he create characters if there wasn't somebody to play the game?
    In this case Toby has a point, Professional Grade graphics cards are going to give better performance, especially in CAD applications. ATI, for example, optimizes the OpenGL performance on the Professional cards and not the Consumer Grade cards, which creates quite a bit of difference in how systems perform.
    However, there is something to be said for a nice inexpensive card that gets you from A to B without a lot of hassle.
    The 8600GT does have dedicated on board memory.
    But for the 8 and 9 series cards there is an update which resolved a lot of issues, including crashes on Vista Operating systems.
    Regards
    Regards
    May 2005
    could you give me a model of a good ati card that is as good as the 8600gt if not better for around the same price i want to try out one of those radeon cards
    John
  • Page 1 of 2 12 LastLast
    1. Need Help!- Importing SurfCam IGES files into Alibre
      By lkenney in forum Alibre Design
      Last Post: 01-22-2009, 02:09 PM
    2. Alibre files for VM 5
      By dave6 in forum Visual Mill
      Last Post: 01-03-2008, 02:02 PM
    3. importing files to MC?
      By Rich05 in forum Mastercam
      Last Post: 06-11-2007, 01:19 PM
    4. Importing dwg.files
      By wsteve in forum Rhino 3D
      Last Post: 05-09-2007, 03:51 AM
    5. About Importing Files
      By Gorillakilla in forum Mach Software (ArtSoft software)
      Last Post: 04-11-2006, 05:37 PM
