Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 03-02-2009, 07:31 PM
chaz6966 is on a distinguished road
post problem with fanuc0 v23
the post worked fine for a few days, now im getting a P for a radius when it should be a R. its an R in the prefixes files.
im also getting a D for tool offset when it used to be an H , now its a D on my G43, and there are no spaces after the line numbers like there used to be, now everything is run together except for the G43 line is the only line with a space betweeen it and the line numbers....
everything in the edit post files is correct... and this problem only started after the 3 day trial thing ran out. i have the full version and key upgrade.
yes i can add spaces but all this crap just started happening, so i have alot of extra editing.
Old 03-03-2009, 09:41 AM
Allen123's Avatar
Allen123 is on a distinguished road
I would check to see if the software is calling the same post you were using during the 5 day thing.
You might just want to re pick your post and try again.
Otherwise I don't know of anything I have run into that causes what you are dealing with.
MC X / HAASV.PST arc problem in the post? Donkey Hotey Post Processors for MC 2 03-25-2008 01:23 AM
Deskcnc post problem StephenSebastia BobCad-Cam 6 12-09-2007 07:19 PM
fanuc0 p/s alarm101 jeremy83 General CNC (Mill and Lathe) Control Software (NC) 5 05-25-2007 05:42 PM
Problem with Fadal post MojosMachine Surfcam 8 03-05-2007 11:33 AM
post problem foamovercast General Metalwork Discussion 0 10-17-2005 11:27 PM
