Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-26-2009, 12:11 PM
chaz6966 is on a distinguished road
milling tools files, changing cutter sizes.
hows come when i change the tool from the 1/2 ball that came with the system..... to a 1/8 .030r endmill, manually...( the 1/8 is still there when i reopen) ... bobcad still gives me a program(toolpath) with the .250 radius of the 1/2 ball tool.
this happens in v22 and v23.
thanks for any replies, chuck
Old 02-26-2009, 03:53 PM
BurrMan is on a distinguished road
When you edit a tool in a feature, it will automatically be added to the tool database. Next time you start to type .125 with a corner radius of .0625 it will automatically select the tool you had created previously.
If you create a toolpath, then change the tool settings, you have to compute the toolpath again to have it reflect the new tool value.
Old 02-26-2009, 07:46 PM
milling tools file
if i pick select tool it will show me the tool that i have typed in there.
if i pick manual tool and type in what i want it will record what i type.
but both of these when i rerun the toolpath it still gives me the toolpath of the 1/2 diameter .250r end mill.
if i edit thesystem tool it will give me the correct path most of the time but i cant edit the tool number when i pick system tool...
so select tool will enter all of my data in the lines but it still gives me the 1/2 by .250 rad cutter toolpath, i can tell cuz the tool path lines arc way off the geometry. ( even when i pick recompute tool path)
is there something else im doing wrong.
thanks, chuck
Old 02-26-2009, 08:31 PM
If you want to manually add tools, do this from the "milling tools-tools" edit dialogue, not a feature edit. This may be what your experiencing.
I believe V22 had some issues with manual tools that others here may know more about how to deal with. If you just specify your tool definition from the feature edit dialogue, then the toolpath will adjust accordingly.
Old 02-26-2009, 09:46 PM
Also if you want to set your own tool numbers, Right click milling tools and choose Verify Tool Assignment. Deselect Use Automatic tool numbering and renumber your tools.
Problem- T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER) dharschman Toolgrinding & Toolgrinding Machines 3 09-13-2010 01:25 PM
Cutter shapes and shaded tools? Bill Grant NCPlot G-Code editor / backplotter 17 07-13-2008 04:58 PM
tools changing in eia program andrejl Europe Club House 0 11-28-2007 03:48 PM
Npt thread milling pre hole sizes magneto259 General Metalwork Discussion 2 04-12-2007 07:33 AM
Changing imported files cncuser1 Mastercam 3 04-11-2007 08:09 PM
