Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-26-2009, 12:06 PM
chaz6966 is on a distinguished road
disapearing surfaces/wire geometry v23/22
is there anyway to stop surfaces and wire frame geometry from disapearing .
when i have more than one file up so i can go back and forth to see differences or just work on another file for a few. goemerty or surfaces will just disapear from the file that im not working on.(not actively).
it does this in 22 and 23.
and if you make the mistake of saving when you close it and you didnt check to see if anything was gone then your screwed.
Old 02-28-2009, 10:24 PM
woffler is on a distinguished road
I to am having the same problem if you change the view you can sometimes find it and then switch back and it will somtimes it will appear i have not figured out whats causing it yet if i here ill get back to you.
Old 03-02-2009, 03:46 PM
Allen123's Avatar
Allen123 is on a distinguished road
What I do a lot of it cutting and pasting parts from one file to the next.
Not all the time but enough the surface either change color, like a transparent view or something very strange, or they drop all together.
This happens to me in V22 and V23 also.
I have no idea on this one, but I wish there would be a fix or for it. I think it's some kind of memory issue
I run 2 gbs of ram , what about you?
Old 03-05-2009, 09:50 AM
DonW is on a distinguished road
That's happened to me a couple times now with V23. I think Allen is right and that it's more of a memory or graphics memory issue. I simply save the file, close it, close BC and re-open everything and it's back. Not that big of a deal.
Old 03-05-2009, 06:34 PM
yes it happens to me in 22 and 23.
i have 4meg of ram and a 256 grafix card on my home dell and it still happens.
on v23 when i open dimensioning my decimal places is 3 and scale factor 25.4.
it will not go by my default or part settings of 4 and 1 scale...
does anyone else have this problem...
Old 03-05-2009, 06:56 PM
BurrMan is on a distinguished road
Seems to stick and stay over here. What is the build number of your install?
Old 03-05-2009, 07:36 PM
*Registered*
HMB3000 is on a distinguished road
Only the people that have not done the update to V23 have this issue with a scale factor of 25.4... as it was fixed in last update
Old 03-05-2009, 08:05 PM
v23 build (1276)
bobcad tech said this was the newest update.
Old 03-05-2009, 09:47 PM
*Registered*
you may have had a bad download...this issue was fixed...maybe you should try a complete re-install
Old 03-06-2009, 12:21 AM
Yeah and with such wierd and horrible problems you are getting Ide bet somewhere you missed something. One of the differences I thought I saw was most of the posted updates were "Updates" which left things missing if you used it as an install. You have to install from the original full build then run the 1276 package as an update to your install.
See if that helps.
Do you have an original installation file? Not the "Demo Install". Those demo installers have several with less than full stuff.
If your unsure at all, call support and get straight over the phone.
power supply size? for multi wire (total 250 inches of wire) DanOSB CNC Wire Foam Cutter Machines 5 03-02-2009 05:34 PM
geometry Htech Fanuc 1 12-09-2007 12:25 PM
rotating geometry and surfaces flinty Mastercam 19 06-13-2007 09:10 AM
Geometry from NC rherman BobCad-Cam 2 09-21-2006 08:10 AM
Associated toolpaths and geometry Paul G. Swartz Surfcam 1 09-12-2006 12:42 PM
