Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-24-2009, 09:08 AM
chaz6966 is on a distinguished road
boundary with slice plannar
shouldnt bobcad keep the toolpath within the boundary instead of using it as a center line for the toolpath...
i would think the toolpath should be 1/2 cutter diameter inside of boundary.
is it also going to wipe out the details within the boundary by half the cutter diameter.
Old 02-24-2009, 10:50 AM
moldmker is on a distinguished road
Offset the boundary in by half the cutter diameter.
v21 has option to contain to the outside of tool, v22/v23 does not.
edit: This is a prime example why you should almost always pick the whole model as the Geometry. If the boundary doesn't contain the tool correctly, worst that will happen is the path will climb the adjacent feature.
I got your file and will look at it soon.
moldmker
Do you need boundary offset or pocketing... JohnKeklak Product Announcements & Manufacturer News 0 05-24-2007 11:12 AM
How to Slice a part into several Sections? GisMo Solidworks 5 09-11-2006 12:37 PM
Boundary box from 9.1 to X? tt_raptor_90 Mastercam 3 06-08-2006 02:24 PM
BobART (v20) 3D Machine to Boundary mc9design BobCad-Cam 0 07-23-2005 07:16 PM
slice command turmite Rhino 3D 21 04-20-2004 04:16 PM
