Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-23-2009, 09:18 AM
chaz6966 is on a distinguished road
machining block letters
i have sunk block letters into a solid .012 deep for a logo.
some are .031 wide some are .125 wide(larger size).
whats the best way or toolpath to machine them in bobcad.
do i have to pick each one individually and machine one at a time.
my toolpath crashes through the solid to the next letter. on some of them.
z level finish v22.
the block letters were extracted from the solid to leave an impression in the block for depth of detail.
Old 02-23-2009, 10:57 AM
Allen123's Avatar
Allen123 is on a distinguished road
If the letters are flat on the bottom, then the best bet would be to do a pocket for these letters.
If you are running v22 you will want to create a pocket feature for every letter as to control the machine order.
V23 you would only need one pocket feature because you can optimize the tool path between pockets - in other words have it cut in a logical order -
If you are having an issue with the Z level I would check the solid.
But you really wouldn't want to run a Z level anyway because you'll have a really hard time ( with out editing the code ) to get the software to cut at the bottom of the surface. Not sure for Z level finish but the rough will not cut at the bottom of a surface it's always just a little bit off.
Example if you had a pocket in a solid that z's position was Z-1.26 or something like that. The Z level rough will not cut to Z-1.26. You would think you could just take that depth a divide by number of passes and have it finish that bottom surface, but nope that doesn't work it still off.
So in order to finish a flat you need to run a 2D pocket for finishing.
Pocketing around letters ? SScnc Mastercam 4 12-17-2008 08:41 AM
Raised Letters Astroguy Mach Mill 1 09-11-2007 08:42 PM
Trying to chamfer some letters justCNCit Rhino 3D 29 02-08-2007 03:41 AM
raised letters zcases OneCNC 1 01-13-2007 12:53 PM
RS232 program block by block smoregrava General CNC (Mill and Lathe) Control Software (NC) 3 12-22-2005 01:52 AM
