Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-21-2009, 01:50 PM
chaz6966 is on a distinguished road
bottom of 3d pocket
z level finish, is there anyreason that z level finish wont cut across the floor fo a 3 d rectangular pocket with radiused corners and bottom.
description in last post.
any help would be appriciated.
Old 02-21-2009, 04:03 PM
BurrMan is on a distinguished road
Z Level will do the "Z levels" of a model. Use slice planar to get the x/y flat stuff
Old 02-23-2009, 10:44 AM
Allen123's Avatar
Allen123 is on a distinguished road
The Z level finish is a water line tool path. It is used to clear the vertical areas not the flats.
You could do a planner tool path like burr said, or just do a 2D pocket to finish the flats.
Then run the Z level finish to finish the vertical walls.
This was just a simple pocket to clear stock and finish the flat
Now I did a Z level finish to finish the vertical walls.
Bottom Up approach lsilva Benchtop Machines 4 03-03-2006 12:37 PM
32 finish at bottom of pocket BROCD General Metalwork Discussion 3 03-03-2006 08:26 AM
Milling top and bottom? bigvinney General Metalwork Discussion 7 01-28-2006 10:16 AM
Look at my bottom Graham S DIY-CNC Router Table Machines 21 12-14-2004 03:12 PM
Ok so what is the bottom line? WallCrawler CNCzone Club House 8 06-19-2003 10:51 AM
