Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-17-2009, 10:09 AM
Stampede is on a distinguished road
With AutoCad Drawing.
I think I have an AutoCad drawing, I can open the drawing up, but I can't modify it. I want to be able dimension the drawing. What do I need to do?
Thanks.
Old 02-17-2009, 10:14 AM
LaserPro is on a distinguished road
Try saving it as a dxf file, then see if it will let you dimension it.
Old 02-17-2009, 10:22 AM
moldmker is on a distinguished road
Maybe the whole drawing was saved as a single Block entity.
Select everything and Explode. May need to do it more than once as there can be blocks within blocks.
moldmker
Old 02-17-2009, 01:30 PM
FastBusa is on a distinguished road
autocad dwg.
Open the drawing then do a save as, rename the drawing to something
slightly different. You can still save it to the same file location since it
will have a different name. Make sure that you save it with the version of autocad you have. In the past I had problems with people that had newer
versions than mine.
JIMBO
Old 02-17-2009, 03:17 PM
I've tried everything to dimension this autocad file, in Bobcad. Nothing works, when I explode the drawing, it will only do the arcs. When I dimension the anything, it reads 0. Is there anything else I can try?
Thanks.
Old 02-17-2009, 03:26 PM
autocadfile
I'am not familuar with this bobcad program. What kind of file
formats does it support IE what is the . ext it reads from and saves with
if you want to send me a copy of the file I will open it and see what I can do
I have 3 different drawing programs and a dozen translators.
send to jchildress@whemco.com
Old 02-17-2009, 04:03 PM
spinwheelz is on a distinguished road
Perhaps you can open a new layer to put dims on. This helps keep things separate from the drawing on my TurboCad drawings.
Old 02-18-2009, 01:45 AM
BurrMan is on a distinguished road
Thanks.
Can you post the file? Also, you did say "I think I have an AutoCad file". Could you clarify this?
Need Help!- How too, AutoCad drawing to BMP/JPEG Holmes_ca Autodesk Software (Autocad, Inventor etc) 5 02-17-2009 10:05 AM
Need Help!- converting imported part drawing to mold drawing msomerville BobCad-Cam 6 08-29-2008 07:56 AM
autocad 2d/3d drawing/render into partmaster? BulleTxMagneT Dolphin CADCAM 2 01-28-2008 09:39 AM
Drawing on my CNC monte55 DIY-CNC Router Table Machines 4 01-18-2008 02:10 PM
Autocad LT verse AutoCad LT CNCadmin Autodesk Software (Autocad, Inventor etc) 2 02-03-2004 08:28 AM
