Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-14-2009, 05:04 PM
bink is on a distinguished road
V22 Facing ?'s
I have a part that is "u" shaped that I need to take about .03 off the top of. I want my cutter path to follow the "u" shape of the part. When i use the "mill 2 axis facing" command, it just wants to mill straight across the part as if it were square. Is there another way to do this, or am i just doing something wrong?
Bink
Old 02-14-2009, 05:21 PM
BurrMan is on a distinguished road
When you say U shaped do you mean it is concave in the Z direction? Or are you wanting the facing to be constrained by a boudry instead of just do a full facing patern around an object
Old 02-14-2009, 06:12 PM
part is flat on the table. yeah, i just want the face op to be restricted to the u shape boundary. was thinking i could draw a box around my part and say that my u shape is a pocket, maybe trick it that way.....
Old 02-14-2009, 06:34 PM
moldmker is on a distinguished road
Here's 2 ways:
First is a Pocket op with zero depth.
Second is Profile with zero depth and large stock remaining number (multi passes) and right angle leadin long enough to plunge down off of part.
I recall reading that boundaries in 2d facing was in the works for later release.
moldmker
Old 02-14-2009, 09:05 PM
Thanks, the second way you described is what i am looking for. what did you use in each of the fields to get that tool path, i am pluggin in something wrong. havent been able to quite get it.
Old 02-14-2009, 10:14 PM
ryansuperbee is on a distinguished road
Hi Bink, I have bobcad V22. It sounds like you don't want to face it at all. Being you want to take .03 off the top of a shape sounds more like a "pocket" operation. Have you thought about doing it like this yet?
Old 02-14-2009, 10:31 PM
These values are based on the leg of the U being 1" wide.
I think Bobcad kinda screwed up the naming of the Stock remaining and Spring passes, but that's my opinion. If you take the Stock and divide by Spring pass, that's your approx. stepover amount.
The neg. Side allowance lets the tool overlap the edge of the part.
Play around with the numbers and recompute and you'll see how they work.
Only use the Rough tool, leave the Finish tool at 0 dia..
Good luck,
moldmker
Old 02-15-2009, 06:22 PM
Thanks!
cylinder facing pp-TG General Metalwork Discussion 12 01-30-2009 09:53 AM
Facing Copper Help JWB_Machining General Metalwork Discussion 2 10-31-2008 06:42 PM
Newbie- Facing operation mikeh78 BobCad-Cam 2 07-14-2008 06:08 PM
Need Help!- Facing around a boss macona Mastercam 4 06-07-2008 03:40 AM
Facing impact General Metalwork Discussion 4 02-22-2006 09:24 PM
