Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 02-12-2009, 09:05 PM
b.bixel is on a distinguished road
Question No Basic Predator Items with V23?
I upgraded my dongle from V22 to V23. I download and installed V23 Mill "demo" package from the BCC web site. I don't see any of the Predator items installed that were installed with V22 (Editor and Virtual CNC). Do any of you V23 users have the basic Predator items which were packaged with V22? Did I pay for a down grade or am I missing something here?
Regards,
Bart
Regards,
Bart
Old 02-12-2009, 09:28 PM
BurrMan is on a distinguished road
You can try to uninstall both predators with the add/remove programs control panel, then re-install them from here:
C:\Program Files\BobCAD-CAM\BobCAD-CAM V23\System Files
Old 02-12-2009, 09:36 PM
Thanks BurrMan but I might need to clarify.
I installed V23 on a machine which never had BCC loaded. I don't have the predator icons on my desk top or the apps in my programs menu. So maybe the new install down load from BCC doesn't have the predator software?
So does the V23 have the Predator editor and Virtual CNC 2007 package standard like it does in V22?
Regards,
Bart
Regards,
Bart
Old 02-12-2009, 09:42 PM
I just checked add/remove programs in the control panel, there are no Predator install items there either, just V23.
Regards,
Bart
Regards,
Bart
Old 02-12-2009, 09:48 PM
Yes B thats odd. They should Install with BobCad. You may have downloaded and installed an "Update or Patch" since it seams you dont have a full install.
A good install should run the new V23, then editor then Virtual, along with making sure your "Other" needed components are up to date,
WHere did you get your install from? Can you post the address?
Old 02-12-2009, 09:49 PM
I went to C:\Program Files\BobCAD-CAM\BobCAD-CAM V23\System Files and found only 2 files; "dotnetfx" and "MDAC_typ".
I'm guessing that the down load from BCC is not complete????
Regards,
Bart
Regards,
Bart
Old 02-12-2009, 09:51 PM
Try uninstall the one you just installed and download this one and install it.
http://www.bobcad.net/updates/V23.02.001_update.exe
If this doesnt produce a Predator install with the BobCad i9nstall, please post back.
This one is found by going to http://www.bobcad.com/updates
Burr
Old 02-12-2009, 09:54 PM
I got it here;
http://www.bobcad.com/getdownload.ph...etdownload_V23.
I figured the demo would install everything and my updated dongle would activate what is authorized.
Regards,
Bart
Regards,
Bart
Old 02-12-2009, 10:00 PM
Actually after looking at that file its size is very small at around 200 mb. The full installer is closer to 300 mb.
Try downloading this file first, then run the file from the updtae site against this install.
http://www.bobcadsupport.com/tech
Click the link that says
"Bobcad software installs" and choose V23. Download and install the release version first, then run the update we were just talking about against that.
Post back,
Burr
Old 02-12-2009, 10:03 PM
Originally Posted by b.bixel View Post
I got it here;
Regards,
Bart
Yeah seems that those demo versions arent the release versions. Kindof an MO for BC to get these out which confuse things. I'm going to post something over there to state this as a popint of confusion. (Even from the past)
Make sure you start with a good first install, then run that update file.
Talk to you later.
  #11   Ban this user!
Old 02-12-2009, 10:18 PM
I just looked at the original file name.... "V23_Demo_(BobCAD Only).exe". This didn't register at the time until now.
I'll give the link above a go. It's good to know I didn't buy a down grade!
Thanks for the help,
Bart
  #12   Ban this user!
Old 02-12-2009, 11:02 PM
Well there you have it. You'll have 2 downloads to do and when your done you should have build "1276" listed in the "help-about bobcad" menu.
YOu may want to check that menu before doing the second one to see if the first download is already been moved to that build.
Good luck.
Need Help!- Backplotting in Predator mdlmkr CamWorks 2 03-18-2009 04:19 PM
Predator DNC lyncomputer Computers and Networking 2 09-20-2007 08:13 PM
predator dnc dcr726 Mazak, Mitsubishi, Mazatrol 3 01-15-2005 11:01 PM
Capture Predator Simulation Xeno General CAM Discussion 7 04-28-2003 01:28 PM
